There’s no denying that Darth Vader is one of the most iconic characters in the Star Wars universe. So the fact that noblechairs has teamed up with Disney once more to create the HERO Darth Vader Edition is utterly epic. Dark aesthetics, superior ergonomics – you can feel Vader’s presence just rolling from this gaming chair. So, get practising your best heavy breathing, dust off that red lightsaber, and feel the force with this gaming chair fit for a Sith Lord.
No, I Am Your Father
With the Boba Fett and Stormtrooper chairs already knocking it out of the park, the noblechairs HERO Darth Vader Edition had a lot to live up to. It’s safe to say this gaming chair delivers.
The black oozes with his commanding presence, the embroidered central chest piece serving as a nod to who this chair is really about. Additionally, wide stitching emulates the sculpting of Vader’s armour, accented by the white cross-stitching and dark velour patches. The noblechairs HERO Darth Vader Edition is instantly recognisable as the Emperor’s fearsome right hand. As a result, this chair is phenomenal, and I haven’t even got to the best bit yet.
Darth Vader’s iconic helmet dominates the rear side of the backrest. It may only be two-thirds of his face, but the precise, machine-stitched rendering captures Vader’s menace perfectly. A fitting replica for the Dark Lord of the Sith.
Asteroids Do Not Concern Me, Admiral
A cornerstone of the noblechairs quality is their use of premium materials. The noblechairs HERO Darth Vader Edition is no exception. PU leather is utilised for the upholstery, chosen for its breathable and durable qualities. The plush velour panels add luxury to the finish of this gaming chair. Providing outstanding support, this gaming chair is padded with dense cold foam. Deform-resistant and firm, this material holds its shape even with extended use. Whether marathoning the Skywalker Saga or playing your favourite Star Wars game, this gaming chair remains at the peak of comfort.
Creating a robust foundation, the noblechairs HERO Darth Vader Edition frame is manufactured from stainless steel. Incredibly durable, this material lends great longevity to this gaming chair. Additionally, the five-point base is manufactured from powder-coated aluminium. Each point ends in a large, 60mm caster that consists of a nylon core and polyurethane coating that makes them suited for both soft and hard flooring. Perhaps even the Death Star’s flooring!
You Don’t Know the Power of the Dark Side!
Darth Vader’s meditation pod is what keeps him comfortable while he relaxes, the noblechairs HERO Darth Vader Edition can do the same for you. Equipped with an amazing set of ergonomic features, this gaming chair delivers comfort like no other. The HERO is noblechairs’ largest model with an advanced backrest that includes integrated lumbar support and a memory foam headrest. Plus, the backrest and seat base are both wider, providing ample space between the armrests for you to unwind. Even a Sith Lord needs their comforts.
For getting into the best position, the backrest can recline from 90-degrees to 125-degrees, with 35 possible options to explore. Plus, the tilt rocking mechanism boasts 11-degrees of movement, allowing you to really lean into those ergonomic features. What’s more, the noblechairs HERO Darth Vader Edition is equipped with 4D armrests, so named for their ability to adjust in four directions. They can be manoeuvred in height, depth, swivel, and distance to achieve your perfect set-up.
Who needs a meditation pod when you have a noblechairs?
If He Could Be Turned, He Would Become a Powerful Ally
If you’ve somehow missed the other two Star Wars Gaming Chairs, here is a quick lil’ reminder of just how awesome they are. We have quite the collection now!
noblechairs HERO Gaming Chair Boba Fett Edition
- Green PU leather with red and gold accents
- Stitching and embroidery to match Boba Fett’s armour
- Replica of his iconic helmet on the back
- Superior ergonomics and premium materials
- 60mm casters
noblechairs HERO ST Gaming Chair Stormtrooper Edition
- Classic white PU leather
- Decals and panelling to mirror Stormtrooper armour
- Imperial symbol stitched on the back
- Stylish harness hole
This Will Be a Day Long Remembered
If you chose the Dark Side, for cookies or otherwise, then you’ll be happy to know that the noblechairs HERO Darth Vader Edition is available for pre-order now at Overclockers UK. If you don’t mind me, I’m going to listen to lo-fi versions of the Imperial March and stare lovingly at this chair while I wait for stock to land.
noblechairs HERO Gaming Chair Darth Vader Edition
- PU leather and dense cold foam padding
- Stitching and embroidery to emulate Darth Vader’s armour
- Velour panelling fit for a Sith Lord
- Iconic rendering of Vader’s helmet on the back
When does it come out?
Stock is due to arrive mid-August, but due to the current climate they might land slightly after.
Hope this helps!
