There’s so much to love about our gaming PCs – from the tech behind them to aesthetical features that make each of our battle stations a visual marvel. However, if you decided you want a new look for your gaming system, you’d need to purchase a new case entirely, maybe even alter your component set-up to make it all fit. At Overclockers, we’re ready to change that, with two incredible new cases from Kolink: the Unity Nexus and the Unity Adapt.
Customise with Alternate Front Panels
Both featuring a gorgeous ARGB front panel, the Unity Nexus is equipped with ample side ventilation. The Unity Adapt’s front panel comes with dual-ventilation mesh cut-outs. These mid-tower gaming PC cases with the option to swap their front panels with one from an exquisite range of alternate inspired designs. Sold separately, there are three uniquely designed replacement panels for each case, making for six in total. For the Kolink Unity Nexus, there are the Landscape, Radial, and Vector panels. Then, for the Kolink Unity Adapt, you can choose from the Quasar, Meridian, and Skyscape. No matter which you choose, all have been designed with ARGB in mind to make your Kolink Unity case a beautiful spectacle.
If you purchase multiple panels, alternating between designs is easy and almost seamless using the screws, mounts, and instructions provided. What’s more, with the full quick-release tempered glass side panel, you’ll be able to show off the entirety of your build in style.
Amazing ARGB Cooling
Continuing Kolink’s mark for high quality, Unity Nexus and Unity Adapt cases are armed with some of the best means for cooling. Adding to a Kolink Classic PWM Fan at the front, each case comes with a Void 120mm ARGB PWM fan at the rear for extra ARGB lighting as well as first-rate airflow. What’s more, both of these mid-tower cases have the room to install a further two 120mm or three 140mm fans on the front or rear. Three further 120/140mm fans can be added to the roof as well.
Users who like radiators in their set-up won’t have to worry either, as the Kolink Unity and Adapt cases support a 420mm radiator on the front, 360mm on the top panel, and a 120/140mm panel at the rear. Whichever cooling set-up you prefer, the Kolink Unity Nexus and Adapt cases are easily up to the task.
Ample GPU, PSU, and Storage Space
Both cases sport a sleek yet unobtrusive aesthetic, each with an entirely black interior. Behind the Kolink Unity Nexus and Adapt’s PSU shroud for either a pair of 3.5” HDDs or 2.5” SSDs. Those looking for even more storage will find room for a pair of supplementary 2.5” SSDs behind the motherboard plate, by using the included removable brackets. For troublesome dust, you’ll have access to a removable filter under the case, suitable for an ATX PSU up to 250mm.
Graphics cards up to 415mm long (less if using front cooling) and CPU coolers up to 180mm are supported in these mid-tower cases. Using a compatible Kolink PCI-E riser cable (sold separately), up to triple-slot VGA can be installed vertically as well. Also supporting motherboards up to E-ATX in format, the Kolink Unity Nexus and Adapt cases both house a mounted I/0 panel for a variety of connectivity options: one USB 3.2 Type-C, two USB 2.0, one USB 3.0 Type-A, and HD-Audio. For sleek and tidy cable management, these will feed directly right into your motherboard, along with being able to sync up your ARGB as well with the software provided.
The Kolink Unity Nexus and Kolink Unity Adapt Mid-Tower Cases come with everything you could want from a gaming PC chassis and more. Along with support for extensive cooling, GPU, and storage options, the ability to customise your front panel with an alternate design will make your gaming PC truly feel like your own.
The Kolink Unity Nexus/Adapt Mid-Tower Gaming PC Cases
- Full ARGB front panel
- Swappable alternate designs available
- Pre-installed front & rear fans
- Quick-release tempered glass side panel
