Cable management is a necessary evil of all our gaming PCs. It does not, however, need to be boring. This is where the new Lian Li Strimer+ Extension Cable comes in. Featuring three 8-pin adaptors, high-quality build materials, and a dazzling array of RGB lighting, this is the upgrade your cable management has been waiting for.
![Lian Li RGB extension cable with triple 8-pin header.](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/lian-li-strimer-plus-extension-cable.png)
The Features of Lian Li Strimer+ Triple 8-Pin RGB Extension Cable at a Glance:
- 30cm of cable, ideal for reaching your GPU without clutter
- RGB lighting with over 77 effects
- High-end braided cable with integrated silicone strip
- Three 8-pin connectors for great flexibility
- Even and smooth bend across the whole cable
- Included RGB Controller for adjusting RGB speeds and brightness
Cable Management Glow-Up
This is the latest in cable management from Lian Li, using high-end braided cables with great flexibility. There will be no more kinks in your cables, thanks to the addition of an integrated silicone strip, they will bend evenly for a smooth and satisfying finish. Its 30cm length is the perfect size for reaching your GPU without cluttering because of unnecessary leftover cable. The triple head 8-pin adaptor will connect to most graphics cards on the market and deliver power in style.
Inside and out, the Lian Li Strimer+ exudes premium quality and longevity. This is going to light up your gaming PC for a long time! Get ready for your system to glow with the 162 addressable LEDs running the length of this cable. Choose between over 77 insane lighting effects or keep things simple with vivid, static colour – there is a setting for you, whatever your aesthetic. Not only that, you can add your own spin on the lighting effects by adjusting the speed and brightness.
The flexibility does not stop here, either. This amazing light show can be controlled from either the included RGB controller or through your motherboard’s built-in RGB software. The Lian Li Strimer+ RGB controller is a simple device with four buttons for you to scroll through the effects, colours, speeds, and brightnesses. Alternatively, once connected via a 3-pin 5V aRGB header, take more comprehensive control over your lighting using your motherboard software.
To complete the look of your set-up, the Lian Li Strimer+ can be connected to additional aRGB devices for a synchronised light show. It’s time to level up your cable management!
Lian Li Strimer+ RGB Extension Cable
- Triple 8-pin adaptor
- 30cm braided cable
- 162 addressable RGB LEDs
- Over 77 lighting effects
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/lian-li-strimer-plus-triple-8-pin.jpg)
