Getting more FPS out of your GPU is every gamer’s dream. With NVIDIAs latest update to their AI-powered DLSS, all your dreams can become a reality.
With Deep Learning Super Sampling (DLSS), NVIDIA offers gamers an almost too good be true feature: Same PC + Same visual quality = Higher FPS. What’s more, all NVIDIA RTX GPUs can utilise this innovative technology in a range games.
Same Graphics Card, More Power
We promise it’s not black magic, DLSS uses a highly complex image enhancement technique. To oversimplify the process, games are rendered by your GPU in a lower resolution and then the image is upscaled using an AI-supported neural network.
4K Quality, With just 1080p System Requirements
To play at 4K with any reasonable FPS is still out of the reach of the majority of gamers. This is especially true in current generation AAA games. Thanks to DLSS this is no longer the case! Your GPU only has to render the game in a lower resolution such as 1080p. This is then upscaled by DLSS thanks to the AI tensor cores on RTX GPUs. Notably, this process is able to enhance your games without any noticeable drawbacks, perfect for finally being able to enjoy ray tracing in the latest games.
The Perfect Complement to Ray Tracing
Overall, DLSS promises to achieve a significant performance gain in games, which will allow you to play at higher settings or enjoy higher FPS with your existing settings. DLSS then is perfect for enjoying the performance-hungry ray tracing. One of RTX graphics cards main selling points is the introduction of real-time ray tracing, which boasts truly beautiful and realistic lighting. However, this feature requires a hefty PC in most games that support it. DLSS offers the ideal solution to these requirements and should help display games smoothly with ray tracing turned on.
What Hardware Do I Need For DLSS?
NVIDIA rolled out DLSS alongside their first generation of RTX 2000 graphics cards and then again with their RTX 3000 and 4000 GPUs. If you’re ready to upgrade and enjoy DLSS, ray tracing, and more check out the range of 2000, 3000, and 4000 series cards below.
Graphics Card | DLSS Support? |
RTX 4090 | Yes |
RTX 4080 Super | Yes |
RTX 4080 | Yes |
RTX 4070 Ti Super | Yes |
RTX 4070 Ti | Yes |
RTX 4070 Super | Yes |
RTX 4070 | Yes |
RTX 4060 Ti | Yes |
RTX 4060 | Yes |
RTX 3090 | Yes |
RTX 3080 Ti | Yes |
RTX 3080 | Yes |
RTX 3070 Ti | Yes |
RTX 3070 | Yes |
RTX 3060 Ti | Yes |
RTX 3060 | Yes |
RTX 3050 | Yes |
RTX 2060 | Yes |
Gigabyte GeForce RTX 4060 WindForce 2X OC 8GB GDDR6 PCI-Express Graphics Card
- 8GB GDDR6
- 2475MHz Boost Clock
- VR Ready
- DLSS
- Real-Time Ray Tracing
The perfect entry into NVIDIAs RTX 4000 series, is the Gigabyte GeForce RTX 4060. What’s more, with 8GB of GDDR6 memory, a boost clock of 2475MHz, and DLSS support this GPU is ideal for the mid-range gamer.
ASUS GeForce RTX 4070 Dual OC White 12GB GDDR6X PCI-Express Graphics Card
- 12GB GDDR6X
- 2550MHz Boost Clock
- VR Ready
- DLSS
If you’re in need of the best performance possible, the ASUS GeForce RTX 4070 offers outstanding quality gaming. Featuring 12GB of lightning-fast GDDR6X memory alongside a 2550MHz boost clock, this GPU will outperform just about anything. Additionally, with DLSS support you can push any game to max settings at insane resolutions such as 8K.
What Games Support DLSS?
One notable recent entry into the ever-growing list of games with support for NVIDIA DLSS, is Escape from Tarkov.
Get ready to snipe on customs or rat around on interchange with higher FPS than ever before, and you’re going to need all the help you can get in this unforgiving First-Person Shooter. Cheeki Breeki!
It’s not just Tarkov either! There are over 100 games that now support NVIDIAs DLSS. Others include:
Ready to Get the Most From Your GPU?
It’s no secret that DLSS offers a huge advantage to gamers. Whether you’re looking to crank up those quality settings in Red Dead Redemption or get the most FPS possible in Call Of Duty: Vanguard, DLSS is a great benefit of NVIDIA GPUs. What games will you be using DLSS in?
