The Bitfenix Prodigy PC case was a regular site across Lan halls and desk spaces when it was first released back in 2013. Its small size, futuristic design and useful carry handles made it stand out from the crowd. This legendary case has now been re-released as the Bitfenix Prodigy M 2022. It comes with several upgrades and updates that make it the ideal choice for a powerful yet portable system. After all, events are rescheduled, tickets are booked and it’s time to swap that huge tower for a transportable compact PC.
Throwback photos:
With the Prodigy M 2022 the choice is yours:
The Bitfenix Prodigy M 2022 uses the same futuristic design as the original but it’s been updated with modern features and a sleek style that’s available in several different variations. You can opt for stand out white which is ideal for reflecting RGB lighting or choose to be stealthy with the all-black version.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_215_01-1024x1024.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_212_01-1024x1024.jpg)
The options don’t end there either. The Prodigy M 2022 is also available as an ARGB variant. To save time and money it comes with a total of 3 120mm ARGB fans and a controller. The addressable lighting can be changed between different effects or connected to your motherboard to create a synchronised light show with your other ARGB components.
Create a powerful and portable PC:
The Prodigy M 2022 might have already impressed you with its good looks. But what is it like to build in? Well, you’ll be pleased to know despite its compact size there’s plenty of space to build the gaming PC you’ve been dreaming of. Behind the stylish exterior and smart tempered glass side panel you’ll find space for Mini-ITX and Micro-ATX motherboards.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_214_09-1024x1024.jpg)
Besides great hardware compatibility, the Prodigy M 2022 has been brought up to date with the latest connectivity. This means you can plug in USB C drives, headsets, and USB peripherals quickly and easily. Less time spent setting up and more time gaming. Finally, the Fiberflex carry handles and make it easy to lug to events or your mates’ house. Plus the robust construction will keep your components safe.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_213_07-1024x1024.jpg)
There’s also room for large graphics cards like the RTX 3090 or RX 6900XT. Dual slot GPUs can even be vertically mounted and shown off front and centre. This means a build in this case can pack an impressive graphical performance punch. Additionally, you’ll find support for plenty of storage. Ideal for large game files or detailed creative content.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_215_03-1024x1024.jpg)
Mesh, Mesh and more Mesh:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_212_10-1024x1024.jpg)
All that mesh is crying out for fans and you can install up to seven! As standard, it comes with 120mm and 60mm fans preinstalled. Whereas, the ARGB version comes with 3 fans. If you’re planning on installing a powerful processor an AIO cooler is a great choice and there’s space for up to a 280mm radiator. All this cooling means this compact case won’t overheat your hardware.
Fitting all that hardware into a tiny chassis means airflow is certainly a concern. Thankfully the Prodigy M 2022 has you covered and the mesh top and front panel ensure optimal airflow. It’s even filtered to keep dust out and your components clean. To maintain performance each one is easily removed for cleaning. Air canister, cloth or this thing? The choice is yours.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_215_08-1024x1024.jpg)
Where to buy the Bitfenix Prodigy M 2022
If you love the nostalgic design and up to date features on the Prodigy M 2022 you can get yours right now on the Overclockers UK website. Thankfully, there’s no need to hunt around either as we’ve kindly placed links to the available options below.
Bitfenix Prodigy M 2022 in Black
A blank slate for a sleek and stylish PC build.
Available now for £85.99
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_212_01-1-1024x1024.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_213_01-1-1024x1024.jpg)
Bitfenix Prodigy M 2022 in White
Matching white mesh, panels and fans ideal for creating a flashy all-white PC.
Bitfenix Prodigy M 2022 ARGB in Black
Smart black design with included ARGB fans and controller for a great light show.
Available now for £104.99
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_214_01-1024x1024.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/09/GEBF_215_01-1-1024x1024.jpg)
Bitfenix Prodigy M 2022 ARGB in White
Bright white reflects the light from the included ARGB lighting so you can create the ultimate compact RGB PC.
