It’s the age old question – AMD or NVIDIA? Both AMD and NVIDIA graphics cards come equipped with so many cutting-edge features, including their intelligent adaptative sync technologies – G-Sync and FreeSync.
However, instead of being torn between the two and weighing up the differences in performance, did you know that FreeSync is compatible on NVIDIA graphics cards? Thankfully, as the PC experts, we’ve put together this guide detailing what AMD FreeSync is and how you can use it with your NVIDIA GPU, along with a few of our top FreeSync compatible monitors.
What is AMD FreeSync?
FreeSync is AMD’s official adaptative sync technology which allows your GPU or APU to control the refresh rate of your monitor. Thanks to AMD FreeSync, you can enjoy silky-smooth frame rates with virtually no input lag, screen tearing, or display stutter. All of which combined results in an optimised gaming performance, with no unwanted performance loss or poor visuals.
In order to utilise AMD FreeSync technology, you will need a compatible FreeSync gaming monitor.
Does AMD FreeSync Work with NVIDIA GPUs?
Whilst G-Sync is NVIDIA’s own built-in adaptative sync technology, you can use FreeSync with your NVIDIA graphics card.
In 2019, NVIDIA revealed that all of their graphics cards would now feature support for FreeSync, however there are a few requirements that you must meet. This includes:
  • Your PC must have all the latest NVIDIA drivers installed
  • You must connect your GPU via the DisplayPort only
  • FreeSync is only compatible with GeForce 10 series cards or above
Once you’ve updated your graphics card drives to the latest available, you will need to enable FreeSync and G-Sync on your compatible monitor.
AMD FreeSync Compatible Gaming Monitors
If your monitor isn’t compatible, however, we’ve included a few of our top compatible monitor recommendations!
Gigabyte M34WQ 34” Gaming Monitor
  • 34”
  • 3440 x 1440
  • IPS panel
  • 144Hz refresh rate
  • AMD FreeSync compatible
ASUS TUF VG32AQL1A 32” Gaming Monitor
  • 32”
  • 2560 x 1440
  • IPS panel
  • 170Hz refresh rate
LG 27GQ50F-B 27’’ Gaming Monitor:
  • 27”
  • 1920 x 1080
  • VA panel
  • 165Hz refresh rates
If you want to shop our entire range of compatible gaming monitors – click the button below.
AMD FreeSync FAQ – All Your Questions Answered!
TLDR, no problem! We’ve compiled all the answers to your burning FreeSync questions in one FAQ.
AMD FreeSync is a free-to-use adaptative sync technology. By connecting your GPU or APU directly to your monitor, it allows your graphics card to control the refresh rates. This results in silky-smooth frame rates, zero screen tearing, and much more.
Do I need an AMD FreeSync compatible monitor?
To fully utilise AMD FreeSync, we recommend you purchase a FreeSync compatible gaming monitor. This will allow you to truly optimise your gaming experience with stunning visuals.
Is FreeSync compatible with NVIDIA GPUs?
To keep it short and simple – yes! As of 2019, you can use AMD FreeSync with your NVIDIA GPU.
Are you thinking about buying a FreeSync monitor? What model are you considering or perhaps you’ve recently bought one and have a few tips to share. Let us know in the comment section below.
0 0 votes
Article Rating
Subscribe
Notify of
guest
4 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
Brian
Brian
3 months ago
I have this monitor and I want a better graphics card, im running intel arc a750 titan oc and im getting weird problems with the screen, not just this new screen but on old, discord crashes, weird green flashes when going into full screen sometimes so many weird glitches it’s time to just upgrade it but buying this monitor idk how to get a LOT of smooth graphics on every game AT LEAST 60 FPS on 1440p (on 1080p I can get about 60-80 FPS on almost all games)
https://www.bestbuy.com/site/acer-nitro-kg272u-pbmiipx-27-led-wqhd-freesync-gaming-monitor-hdmi-dp-black/6555712.p?skuId=6555712
my pc specs is:
Ryzen 9 5900X 12 Cores
1TB of NVME
16 GB of Ram
Raidmax Cobra 700w PSU
Asus Prime B550 PLUS
Sparkle Intel Arc A750 Titan OC Edition (3 Fan)
Musitex ATX PC Case
I went into a lot of details hoping I can get some answers and shed some light on the fact that I do streaming too and im upgrading my ram with an additional 32 GB (if u guys think that’s needed so I’ll have 48 GB) but I stream a lot and play GTA V heavily modded with graphics and I play a lot of graphic intensive games.
So? Point is if u didn’t wanna read what card should I get that’s affordable and will last me forever and work with my freesync acer nitro monitor?
Emily Haylock
Editor
3 months ago
Reply to  Brian
Without knowing your budget, it’s hard to guage what qualifies as affordable. Based on what you’ve said here, an RTX 4060 Ti could be a good fit?
If you need further advice, our Customer Services team is always ready to help – you can contact them here. Alternatively, the Overclockers UK Forum could be a good place to discuss this.
Brian
Brian
3 months ago
Reply to  Emily Haylock
I have a $500 dollar budget.
Emily Haylock
Editor
3 months ago
Reply to  Brian
Our customer services team should be able to help you fully.
