Recently, Glorious PC Gaming Race dropped their brand new Lynx Switches, delightful in their pastel blue shell. Well, now Glorious have decided to level up your peripheral game even further by launching the Model D Wireless Gaming Mouse and pre-lubed Panda Switches. Available for pre-order now at Overclockers UK, these will make stylish additions to your gaming PC.
![Glorious Model D Wireless black and white](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/Twitter-PT-Glorious-Model-D-1024x585.png.webp)
Model D Wireless
Bringing the Model D Gaming Mouse up to speed with its Model O brethren, Glorious has released a wireless version of this honeycomb mouse. Connected via 2.4GHz wireless, this mouse has the lowest latency amongst top-tier gaming mice and is equipped with a next-gen BAMF sensor. An incredibly responsive mouse, this sensor has a low power draw, extending the battery life of this mouse, while you can enjoy 400 IPS tracking and up to 19,000 DPI. Fully programmable, no less.
Features |
71-hour battery life |
2.4GHz wireless |
Honeycomb shell |
RGB lighting |
69g |
Up to 19K DPI |
![Glorious Model D Wireless Optical Mouse - Black](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/model-d-wireless-lifestyle.png.webp)
In addition to being highly responsive, the Model D Wireless is incredibly lightweight – especially for a wireless mouse – meaning you can tear up the battlefield with quick flicks with ease. No one will stand in your way with this mouse. Plus, with its contoured and honeycombed shell, this is a wonderfully comfortable mouse to have under your palm for extended periods. Reduce strain and fatigue while you dominate your favourite game, it’s that easy.
Available in two colours, there is a Model D Wireless Gaming Mouse for all aesthetics. Go classic with black, or look fresh with a white mouse. Both are accented in fully programmable RGB lighting and provide the same, flawless performance. Plus, with six buttons and support from the software Glorious Core, you’ll be able to fully customise this gaming mouse to your exact gaming needs. Tasty.
![GIF with Glorious Model D Wireless features](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/glorious-model-d-wireless-gif.gif)
Other notable features of this mouse include the use of high-quality materials in its construction, enhancing the longevity of the product. Plus, with Teflon skates, you can glide seamlessly across your desk or mouse mat for plenty of gaming sessions to come.
Pre-Lubed Panda Switches
For those who cannot get enough of customising the feedback and typing experience of their GMMK Pros, then you’ll love the Pre-Lubed Panda Switches. Manufactured from premium materials, these Panda Switches have been optimised for tactile feedback with a satisfying thonk. Non-lubed switches can be purchased, but having them pre-lubed by experts takes out a lot of the guesswork. Only the necessary parts have been dressed with Glorious G-Lube, the upper housing, stem, and spring.
Features |
36 x switches |
Premium materials |
Pre-lubed with Glorious G-Lube |
Tactile |
Compatible with GMMK Pro and Cherry profile keyboards |
Smooth operation |
![Glorious Panda Switches](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/glorious-panda-switches.png.webp)
Ok, now we are done giggling about lube, it’s time to talk about the typing experience. With the Glorious Panda Switches, you get tactile feedback thanks to the strong bump at the start of the downstroke. Enjoy speedy typing thanks to the short pre-travel distance and snappy upstroke, with an audible thonk. Crunchy, yet satisfying.
Utilising the standard, 3-pin bottom shell, the Panda Switches are compatible with most keyboards using a Cherry profile. Plus, we have plenty of barebone keyboards available at Overclockers UK, if you would rather build from the bezel up than hot-swap switches out of your existing keyboard. Obviously, the Glorious GMMK Pro being an ideal contender.
Lastly, the different parts making up the Panda Switches are all premium grade. Check out this table of the bits and pieces:
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/Glorious-Panda-Switch-GLO-SWT-HPANDA-Lifestyle-1-1024x379.png.webp)
Part | Material | Benefit |
Top Shell | Polycarbonate | Sturdy, strong, hard structure |
Stem | POM aka polyoxymethylene | Highly crystalline, superior polymer, low friction properties |
Spring | Nickel-plated stainless steel | Consistency with every click |
Leaf | Premium-grade copper | High durability |
Bottom Shell | Nylon PA66 | Cohesive durability and stability |
Most Glorious
If you’ve been waiting for a push to upgrade your peripherals, consider this me pushing you. Pre-order now and let future-you enjoy this present.
- BAMF sensor
- Up to 19,000 DPI
- RGB lighting
- Teflon skates
- 2.4GHz wireless
- Available in two colours
![Glorious Model D Wireless Optical Mouse white](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/glorious-model-d-whtie.jpg.webp)
![Glorious Panda Switches](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/Screenshot-2022-05-25-090445.png.webp)
Glorious pre-Lubed Panda Switches
- 36 switches
- Pre-lubed stem, upper housing, and spring
- Premium-grade materials
- Tactile feedback
- Satisfying thonk
