We’re taking a deep dive into both Ducky One 2 and One 3 keyboards, showcasing all the key features and differences, to help answer which keyboard you should buy. Let’s waste no more time and jump straight to it.
Ducky One 2 vs Ducky One 3 – what’s the difference between these two popular keyboard series and which one is right for your gaming set up?
Ducky One 2
Ducky One 2 is their line-up of mechanical keyboards. These keyboards have been crafted with gamers and typists in mind to deliver optimised comfort and stability. Available in multiple form factors, including full-sized and mini 60% variants, you can find a Ducky One 2 that is sure to suit both your in-game demands and set up requirements.
These keyboards sport a huge variety of switches from Cherry MX Speed Silver to MX Blue. You can’t freely swap the key switches, meaning you are limited to the ones that come included with the keyboard, so be sure to select the right model.
In addition to this, making your desk look stylish, Ducky One 2 keyboards feature unique colour schemes and designs from classic Tuexdo, all white, to Peter Pan inspired. Not every model includes per-key RGB backlighting, therefore, if you want a keyboard with RGB, be sure to check that your chosen Ducky One 2 has it.
Key Features of the Ducky One 2 Keyboard |
Available in UK and US layouts |
Various form factors from 60% mini to full-sized |
Multiple models available with different key switches |
PBT keycaps |
Unique colour schemes and designs |
Per-key RGB backlighting (depending on the model) |
Ducky One 3
Ducky One 3 is their latest generation of gaming keyboards. Designed with Quack Mechanics, they have been engineered to deliver balanced tuning, improved stability, whisper-quiet typing, and much more.
With a Ducky One 3, you can configure this keyboard to perfectly suit your in-game demands thanks to the hot swappable PCB. You can choose between hundreds of different key switch types to find the set that perfectly suits your preferences. What’s more, to boost your typing even further, each Ducky One 3 keyboard comes equipped with PBT keycaps. These keycaps have been constructed from durable plastic and finished with a frosted texture for improved grip during intense boss battles.
In addition to all of this, Ducky One 3 keyboards are available in a wide range of form factors, from hefty full-sized variants to space-saving TKL keyboards. In fact, these keyboards are some of the few available in a UK, full size layout that also features hot-swappable technology. Thanks to this, you won’t have to compromise on performance or comfort even if you have a smaller set up.
Finally, for that added unique touch to your desk, Ducky One 3 keyboards come in a variety of colours from all-out yellow for that classic Ducky look to stylish Matcha or Fuji. Plus, with customisable per-key RGB backlighting, you can create the perfect backdrop that suits your desired aesthetic.
Key Features of the Ducky One 3 Keyboard |
Various form factors from mini 60% to full-sized |
Hot-swappable PCB for complete freedom over which key switches you have |
PBT keycaps |
Ducky One 2 vs Ducky One 3 – What are the Key Differences?
Model | Keycaps | Selection of Sizes | Selection of Switches | Selection of Colours | RGB Lighting | Hot Swappable Switches |
Ducky One 2 | Double-shot PBT keycaps | Yes – lots of variety in sizes 60% mini to full-sized. | Yes – models with lots of different key switches E.g. Cherry MX Red | Yes | No | No |
Ducky One 3 | PBT keycaps | Yes – lots of variety in sizes 60% mini to full-sized | Yes – models with lots of different key switches E.g. Cherry MX Speed Silver | Yes | Yes | Yes – you can freely swap between different key switches thanks to the hot swappable PCB. |
Which is Better: Ducky One 2 vs Ducky One 3
Ducky One 2 vs Ducky One 3 – which one you choose all comes down to your individual preferences and typing needs.
If you want the freedom of complete customisation, then Ducky One 3 is for you. The hot-swappable PCB is what makes this keyboard shine. You aren’t limited to a single set of key switches or keycaps. In fact, you can even sport multiple sets at a time. Why not arm your WASD or arrow keys with ultra-fast MX Speed Silver key switches for that competitive edge in-game?
However, if customisation isn’t your thing, then a Ducky One 2 boasts everything you need in a mechanical gaming keyboard. Sturdy construction, endless key switches to choose from, and unique designs. Just be sure to double-check that your model is equipped with the key switches and any additional features you want, such as RGB lighting.
Both Ducky One 2 and Ducky One 3 keyboards are available in different form factors. No matter what model you choose, you won’t have to compromise on performance or looks to suit the size of your set up.
Go Quackers for Ducky
Are you looking to upgrade your keyboard to a Ducky One 2 or One 3? Then look no further. At Overclockers UK, you can find plenty of models from both these keyboard series. We’ve included two of our favourites below, but you can shop the entire range by clicking the button.
Ducky One 2 Pro Mini 60% Mechanical Gaming Keyboard
- Ducky One2 model
- 60% mechanical keyboard
- UK ISO layout
- Quack mechanics
- Cherry MX Speed Silver key switches
- Double-shot keycaps
Ducky One 3 Mist TKL 80% RGB Mechanical RGB Gaming Keyboard
- Ducky One3 model
- TKL 80% form factor
- UK ISO layout
- Hot-swappable PCB
- Quack Mechanics
- PBT keycaps
- Per-key RGB backlighting
Learn More About Your Ducky Keyboard
Ducky One 2 vs Ducky One 3: Which Did You Pick?
Which Ducky keyboard did you go for? Let us know which one and why in the comments.
