Have you recently purchased a Ducky Zero 6108 and are stuck trying to figure out all the different configuration options or keyboard shortcuts?
Well, you’re in luck, for we’ve compiled the Ducky Zero 6108 manual into one handy blog post, detailing everything you need to know including all the keyboard shortcuts. We have even linked the manual for your complete convenience.
Short of Time?
Are you short on time to read our complete breakdown of the Ducky Zero 6108 and its manual? Don’t worry, we’ve linked the manual below for ease. Simply click the button to get started.
The Ducky Zero 6108 Gaming Keyboard
The Ducky 6108 Gaming Keyboard has been fine-tuned with gamers in mind, boasting silky-smooth typing, superior response times, tri-mode connectivity, and premium materials. With both black and white models available, along with per-key RGB lighting, the Ducky Zero 6108 will blend seamlessly into any set-up, regardless of your chosen aesthetic.
Cutting-edge hot-swappable technology allows you to configure the Ducky Zero 6108 to perfectly suit your gaming demands or typing needs. You can freely swap out the default key switches to a set that better matches your preferences. However, as standard, the Ducky Zero 6108 is available with a wide range of popular Cherry MX switches including MX2A Red, Blue, Brown, or Speed Silver. The PBT double-shot keycaps feature an OEM profile for enhanced durability, and are arranged in a UK ISO layout.
Equipped with intelligent tri-mode connectivity, you can freely choose between 2.4GHz, Bluetooth, or wired – whichever suits your playstyle more! The high-quality rechargeable battery provides a long battery life, meaning you don’t need to worry about your sessions being suddenly interrupted by a flashing low battery light.
The Ducky Zero 6108 Manual
- Model: DKZE2408ST3
- Switch: MX Switch
- PBT Double-shot Keycaps
- 100% form factor
- Size: 435 x 135 x 40 mm
- Weight: 1200g
Connectivity
Your Ducky Zero 6108 will be in wireless mode by default, compatible with both 2.4GHz and Bluetooth connectivity. However, the switch to turn wireless on/off is located underneath your keyboard if you wish to configure this setting.
If you plug in the USB cable, the Ducky Zero 6108 will automatically switch to wired mode. To change back to wireless, you’ll need to first unplug the USB cable and toggle back to wireless mode.
To see your current connection and battery life status, hold down ‘Fn / Fn + Alt’. Other keyboard shortcuts include:
- Fn + F1 – Bluetooth Mode 01
- Fn + F2 – Bluetooth Mode 02
- Fn + F3 – Bluetooth Mode 03
- Fn + F4 – Bluetooth Mode 04
- Fn + F5 – 2.4GHz Wireless Mode
- Fn + F6 – USB Wired Mode
Lighting
The Ducky Zero 6108 includes customisable RGB lighting. To configure this to suit your aesthetic, here are the keyboard shortcuts you’ll need.
- Fn + F10 – switch lighting mode
- Fn + Left Shift – switch to the previous set of lighting mode
- Fn + Right Shift – switch to the next set of lighting mode
- Fn + X – turn off all lighting effects
- Fn + ↑/↓ – increase or decrease the brightness of the lighting effect
- Fn + ←/→ – increase or decrease the speed of the lighting effect
Extras
In addition to configuring the connectivity and lighting options on your Ducky 6108, there are a few extra keyboard shortcuts. This includes:
- Hold Fn + Windows for 3 seconds – Lock/unlock the Windows key function
- Hold Fn + Left Ctrl for 3 seconds – Caps Lock and Left Ctrl function swap
- When the switch is successful, hold Fn + Caps Lock for 3 seconds and they will switch back
- Hold Left Windows + Right Windows for 3 seconds – reset your keyboard back to factory default
The Ducky Zero 6108 – What You Need to Know
Are Ducky Keyboards Good for Gaming?
Ducky keyboards are an incredible option for gamers as they are fine-tuned to deliver ultra-fast responsiveness and precise typing. Equipped with premium switches and keycaps, Ducky keyboards have been engineered to stand the test of time, no matter how intensive your battle gets. Extra features such as hot-swappable switches and adjustable RGB lighting make them a great addition to any gaming battle station.
Are Ducky Keyboards Hot-Swappable?
Ducky One 3, Project D, and Zero keyboards all feature hot-swappable technology. This means you can freely adjust the default key switches to better suit your demands, whether you want ultra-fast typing or whisper-quiet operation.
We recommend that you check the manual for your keyboard model to confirm whether it includes a hot-swappable PCB.
Are Ducky Keyboards Wireless?
Ducky keyboards are available in both wireless and wired models. The Ducky Zero 6108 features compatibility with both 2.4GHz and Bluetooth connectivity. However, we recommend you double-check your keyboard manual to confirm your model’s settings.
How to Change Colours on a Ducky Keyboard
To configure the RGB lighting on a Ducky keyboard, you’ll first need to refer to your manual to see the correct shortcuts. These shortcuts can vary depending on your model.
We’ve created a helpful blog detailing the keyboard shortcuts for a range of popular Ducky keyboards to help you configure the RGB lighting.
How to Clean a Ducky Keyboard
Cleaning a Ducky keyboard is easy! You’ll first want to make sure you have your keyboard turned off and unplugged. From here, we recommend you try the following steps:
- Turn it Upside Down – flipping your Ducky keyboard upside down and giving it a gentle knock will remove any loose crumbs that might be hiding in-between the keys.
- Brush Your Keyboard – secondly, give your keyboard a brush. You can find plenty of high-quality keyboard brushes that have been designed to reach all those nooks and crannies.
- Compressed Air – cans of compressed air make it even easier to clean your Ducky keyboard. Typically equipped with thin nozzles, they are great for accessing any hard-to-reach spots, along with being perfect for any models that don’t feature removable keycaps.
- Remove Your Keycaps – if you can remove your keycaps, do so! Gently remove them with a dedicated keycap puller and give those bad boys a wash. Keycap baths are great for removing any excess grease or dirt and get your keycaps back to looking factory fresh.
If you’re looking for more great cleaning tips for your Ducky keyboard, be sure to check out our guide.
How to Reset a Ducky Keyboard
To reset your Ducky keyboard back to its factory settings, you’ll need to press a specific keyboard shortcut. This does vary depending on your model, but it typically involves pressing both Windows keys for at least 3 seconds.
We recommend you check the manual for your keyboard to confirm what shortcut you need to press to reset your Ducky keyboard.
Are You Quackers for Ducky?
Can’t get enough of Ducky? We’ve got plenty of helpful articles all about this premium line-up of gaming keyboards.
