Get ready to enhance your FPS gaming with the Endgame Gear EM-C Series Mouse Pads.
These XL mouse mats are constructed of premium materials that facilitate high-performance gaming from your mouse. Woven cloth surface, Japanese Poron base, and stitched edges, these mouse pads have it all!
The EM-C Series
The Endgame Gear EM-C Series has two mouse pads in the line-up. The EM-C and the EM-C Plus. Both are black, with subtle Endgame Gear branding for an iconic finish that will effortlessly blend into any set-up. At 3mm, they are comfortably cushioned, whilst their XL status provides ample space to conduct your battles. Here is a quick comparison of the two mouse mats:
Endgame Gear EM-C Mouse Pad
490mm x 410mm
Endgame Gear EM-C Plus Mouse Pad
500mm x 500mm
Primed for FPS
Now we’ve seen the mouse mats, it’s time to go into a little more detail. The Endgame Gear EM-C Series utilises a woven cloth surface. This particular material makes it perfect for FPS gaming, as big mouse movements are met with a high dynamic friction. Micro-adjustments, on the other hand, have a low static friction. What’s all this for? Improving your aim, of course! Enjoy enhanced accuracy as a result of this premium fabric.
Also helping your FPS performance, are the stitched edges. How, you ask? They utilise a sub-surface stitch that brings the overall profile lower than the mouse pad. As such, your arm won’t rub on the surface, and it will not hinder any of your movements. Comfy and practical. What’s more, the stitched edges also improve durability, bringing all the layers neatly together.
Hella Grip
We’ve covered the top, now for the base. The Endgame Gear EM-C Series utilises Japanese Poron for the base. For good reason, too! This material is cushioned, making for unrivalled consistent thickness with a soft and comfortable feel. But wait, there’s even more. Its texture provides a suction cup-like grip, meaning this mouse mat will not budge. You could be in the most intense FPS battle royale, and this gaming surface will not shift, cinch, or move.
If you need further convincing, why not check out our guide to buying mouse mats? It covers all the ins and outs of a mouse pad, so you can make sure the one you get best suits your set-up.
Elevate Your Gaming Set Up Now!
Does your mouse mat pale in comparison? Lucky for you, the Endgame Gear EM-C Series Mouse Pads are both available to pre-order now at Overclockers UK. Let us know in the comments if you’ll be making the upgrade.
- Woven cloth gaming surface
- Primed for FPS gameplay
- Japanese Poron base material
- Sub-surface stitched edges
- Black with subtle Endgame Gear branding
