If your gaming set-up’s ergonomics are looking a little lacklustre, then perhaps you’re in need of the ThunderX3 FLEX Pro Gaming Chair and ThunderX3 LAB-X Standing Desk.
These latest additions to the ThunderX3 line-up are utter game changers for ergonomics. We’re talking 19 dimensions for adjustment, electronic controls, and features that will have you asking, “Where have you been all my life?!” Ready to redefine ergonomic support? Then read on!
Update Your Ergonomics
There are two new products joining the ThunderX3 line-up: an ergonomic gaming chair, the FLEX Pro Mesh Black, and a height-adjustable standing desk, the LAB-X. Each is packed with ergonomic features to enhance your comfort and gaming set-up, all while looking sleek and modern. Tidy.
FLEX Pro Mesh Black
LAB-X
ThunderX3 Has Your Back
ThunderX3 FLEX Pro
The ThunderX3 FLEX Pro is a chair that can be used in both gaming and office set-ups. The Y-shaped aluminium and nylon frame provides a strong yet flexible foundation. Flexibility is going to be a theme for this chair, as it has self-adjusting features and nineteen ways to configure. Yep, you read that right. Nineteen.
To start with, the 2D headrest, 3D backrest, and 3D lumbar support are all self-adjusting. All you need to do is lean back and let them work their magic. On top of this, they can be further adjusted and positioned to best suit you. The headrest can be manoeuvred up/down and back/forth to best support your neck. On the backrest, you can increase the height, adjust the tilt resistance, and take advantage of a multi-angle lock on the recline. The lumbar support is split into two panels, that conform to you and cradle your back. These can be adjusted in depth and height for some sweet constant support. (Anyone else’s chair starting to sound inadequate?)
Working with all these self-adjusting features is the SYNC6 mechanism which, you guessed it, facilitates six of the nineteen adjustments. This includes the backrest resistance, with four levels to choose from. In addition to this, the SYNC6 mechanism uses a synchronous tilt which makes the backrest and seat base move together at the optimal ratio. As a result, the FLEX Pro moves more naturally with your body for better ergonomic support. The seat base can also be moved back/forth, up/down, and tilted forward for when you really need to lean into the action!
Finally, the 360 5D armrests. These go up/down, front/back, tilt, and can be rotated a full 360-degrees! There will be no more awkwardly positioning your upper body with these armrests!
Discover Full Ergonomic Adjustments on FLEX Pro
Need to see the ThunderX3 FLEX Pro in action? We got you, boo.
Mesh Black
The FLEX Pro is enhanced by the choice of material. The Mesh Black is upholstered with a high-tensile mesh fabric. This offers an unbeatable breathable experience, complete with passive cooling.
ThunderX3 LAB-X
The ThunderX3 LAB-X is an electronic standing desk with a spacious surface area for your PC, monitor, peripherals, and more! Thanks to the silent motor and easy-access controls, you can effortlessly transition from gaming or working seated to standing. Plus, there is a pre-saved “Health” mode and the option for two custom presets to take advantage of, making your set-up even more seamless.
Need some stats? Here we go: the desktop measures 170cm by 75cm, and the height increases from 75cm to 120cm. So much more room for activities!
On top of this, the ThunderX3 LAB-X desk is manufactured from robust materials and has a few cheeky features that will really elevate your set-up. The desktop includes two mesh panels on the left- and right-hand sides and are intended to rest below your gaming PC. As a result, your PC gets an airflow boost – especially if you use the optional fan bracket to add fans below!
Also on the desktop, there is a dedicated tempered glass mouse pad. With its precise tracking and smooth surface, you won’t need an extra mouse mat, and you’ll have complete freedom to execute sweeping arcs and fast flicks. Along the edge of the ThunderX3 LAB-X, there is an aluminium frame track which can be used for add-ons. Included within the scope of delivery are a cupholder and headset hook which integrate nicely with this feature!
Finally, as an important safety feature, there is anti-collision technology baked into the ThunderX3 LAB-X. Should it detect any obstacles when lowering, the desk will automatically stop. This means it is safer for all users and prevents damage.
Introducing LAB-X Motor Ergonomic Desk
Oh yes, we have a nifty little feature video for the LAB-X, too.
Available Now
If your gaming set-up could use a ThunderX3 FLEX Pro or (and!) a ThunderX3 LAB-X, then you’re in luck. These latest products from ThunderX3 are available from Overclockers UK right now!
Stay Up to Date!
Keep your finger on the pulse for all things tech, by signing up to our Newsletter!
