Endgame Gear is back with a brand-new series of gaming mice and accessories. Introducing the Endgame Gear OP1we Series.
The Endgame Gear OP1we Series has everything we need to upgrade our esports peripheral set up and then some. Oh yeah, this series has a new gaming mouse, with a redefined shape, and the modding accessories to match! Has Christmas come early?
What does the Endgame Gear OP1 Series consist of? Short answer: shiny goodies. Long answer: the OP1we Wireless Gaming Mouse (in black and white), OP1we 100% and 99.5% PTFE Skate Sets, OP1we Skin Set (again, both black and white), and an OP1we Switch Set. So. Much. Goodness.
Endgame Gear OP1we Wireless Gaming Mouse
Endgame Gear OP1we Skate Set
Endgame Gear OP1we Skin Set
Endgame Gear OP1we Switch Set
Like to know more? I know you would!
We’ll start with the Endgame Gear OP1we Wireless Gaming Mouse. This features a smaller shell than the XM Series mice, designed to be used with a claw grip. Equipped with a CompX CX52850 microcontroller, this gaming mouse connects to your gaming PC via reliable 2.4GHz frequencies and has an average battery life of a week’s gaming. When you do need to charge, a USB 2.0 Type A to USB-C cable is included, so you can plug in and carry on. Not even low battery will stand between you and the latest AAA games!
Keeping the OP1we pixel-precise, this gaming mouse utilises a Pixart PAW3370 optical sensor, with up to 19,000 CPI, a 400 IPS tracking speed, and 50G acceleration. The CPI is fully customisable, too. The CPI switch has four pre-set levels – 400, 800, 1600, and 3200 CPI – which you can toggle through on the fly. For more precise adjustments, you can use the Endgame Gear WE Series Configuration Software to set CPI in 50 step increments between 50 and 10,000 CPI and in 100 step increments from 10,000 to 19,000 CPI. This software can also be used to configure the lift-off distance, polling rate, and debounce time.
Switches and Hybrid Skate Design
Two of the real shining features of the OP1we gaming mice are the Kailh GO optical switches and hybrid skate design. Starting with the switches, these utilise an optical barrier for incredible accuracy and are rated for 80 million actuations. Durable, right there. What we love most about these switches is the fact they have a mechanical feel to them, for that oh-so-satisfying crisp click action.
The hybrid skate design is delightfully innovative. Upon the underside of the shell, the space for skates can accommodate both large and small skates. (One at a time, of course.) This enables you to tailor the mouse to best suit your set up and gameplay style. The large skates work best with soft mouse mats whilst the small skates are suited to hard mousepads. Either way, you are going to have a smooth and satisfying glide. Plus, a sensor skate is included to provide a constant distance between the sensor and your surface, for consistent performance where it matters most.
Please note that the mouse only comes with the small skates. The large skates are offered as part of the optional accessory.
Mod You Like
The Endgame Gear OP1we has been designed to offer you great flexibility in how the mouse is set up. With the following accessories and mod-friendly design, you can tailor this gaming mouse to fit your exact needs. Switch out your skates, add some extra grip, and even modify the switches!
- 2.4GHz wireless gaming mouse
- CompX CX52890 MCU
- Pixart PAW3370 optical sensor
- Wee-long battery life
- Designed for claw grip
Endgame Gear OP1we Skate Sets
There are two Endgame Gear OP1we Skate Sets to choose from: 100% PTFE in milky white and 99.5% in white. Both offer the large and small skate sets, as well as that all-important sensor skate.
Whichever model you choose, you can enjoy an enhanced glide that mitigates fatigue from rapid movements. These skates have been engineered to elevate your gaming experience, providing you with unparalleled pointer accuracy. Swish!
Endgame Gear OP1we PTFE Skate Set
- Replacement skates for OP1we
- Manufactured from PTFE
- Includes large, small, and sensor skates
- Smooth glide action
- Available in 100% PTFE and 99.5% PTFE
Endgame Gear OP1we Skin Sets
Get a grip! Or rather, a four-piece, pre-cut set of Endgame Gear OP1we Skin Set. Available in black or white, these synthetic rubber grips will enhance your hold and comfort.
There are two pieces for the main buttons and a further two for the side panels. These side pieces actually rest at the thinnest point of the mouse, so these grips can be utilised to customise the shape, as they stand at 0.5mm thick.
- Skin set for OP1we
- Synthetic rubber
- Four pre-cut pieces
- 0.5mm thick
- Available in black or white
The chosen switches in the OP1we gaming mouse have a heavy click, which may not work for you. The Endgame Gear OP1we Switch Set features Kailh GO optical switches from the 60-65gf sorting range. Aka, their optical switch with the lightest click.
These switches come pre-installed on a PCB, which makes it easier for you to install in place of the original main button switches. Simply unscrew the mouse shell and original switches with the included PH000 screwdriver and replace with this switch set. No soldering required! There is even a quick start guide to help you through the process.
Please note: These aren’t intended to be replacement switches; they are alternatives due to their lighter click feel.
- Alternative optical switch for OP1we
- Optical switches from the 60-65gf sorting range
- Light click
- Pre-installed on PCB
- Kit includes all tools needed and a QSG
One of Each Please!
We are super excited about the whole Endgame Gear OP1 series, from mouse to mods. We can’t wait to get our claw grip on them and dominate in esports circles. (That’s how it works right? Good mouse = good at games.) Let us know in the comments if you’ll be making the upgrade, as all these goodies are available to pre-order at Overclockers UK!
