Your desk is nearly complete. You’ve picked the right sized keyboard and you’ve bagged yourself a mouse with the perfect DPI level for you. Now you just need to select the best mousepad and equip yourself with a keyboard mat. Glorious is here today to kill two birds with one launch. Meet the Chroma Key Mouse Mat and the Sound-Dampening Keyboard Mat.
Glorious Chroma Key Mouse Mat
For streamers out there with a mouse cam, let me ask you a question. Is your mousepad boring? Does it look out of place as a backdrop when filming your content? Answered, yes? The Glorious Chroma Key Mouse Mat is the solution. This XXL mouse pad utilises the chroma key colouring, effectively making it a green screen for your desk. Thanks to its wrinkle-free properties, its cloth surface creates the perfect backdrop for visual effects. The perfect way to level up your streaming!
Other benefits of this mouse mat? The Glorious Chroma Key Mouse Mat is a n XXL gaming surface, measuring a whopping 460mm by 910mm. Thus, creating a canvas for your keyboard, mouse, and any other accessories you use while filming. At a plush 3mm thick, this mouse pad will smooth out any bumps or nicks in your gaming desk, creating a level surface on which your mouse will simply glide. Even with the fancy green screen effects, you will have epic control over every swipe, flick, and swish of the mouse.
For peace of mind when life’s little mishaps occur, the Glorious Chroma Key Mouse Mat is machine washable. No spilled coffee is going to ruin your dazzling effects! Once your washing machine has done its thing, simply leave this mouse pad to air dry, out of direct sunlight. Job’s a good’un.
Glorious Sound-Dampening Keyboard Mat
With the Glorious Sound-Dampening Keyboard Mat, you can enjoy a muted acoustic experience when it comes to typing. This gaming surface stands at 4mm thick, packed with a dense foam that is designed to absorb sounds and vibrations from your keyboard. The end result? A muted effect on every keypress. Lush.
Unlike the Chroma Key Mouse Mat, the Glorious Sound-Dampening Keyboard Mat is a compact pad, designed to save on space as well as reduce those decibels. It is best suited for the Glorious GMMK Pro, but will also fit most compact keyboard sizes. This keyboard mat will fit 75%, 65%, 60%, and 40% form factor models, thanks to its 347mm by 145mm surface.
Designed to last, the Glorious Sound-Dampening Keyboard Mat is manufactured from robust materials. Its surface is formed from a durable cloth with stitched edges, to prevent fraying. Helping your keyboard to stand firm, the base is an anti-slip rubber. There will be no shifting whilst you take on that boss battle!
Level Up Now
Both of these gaming surfaces are available to pre-order now, at Overclockers UK. If you plan on using the Glorious Chroma Key Mouse Mat on stream, be sure to drop your handle below. We’d love to see what effects you use! Don’t you just think the Sound-Dampening Keyboard Mat will be great for some ASMR content, too?!
- XXL gaming mouse pad
- Chroma key coloured for green screen effects
- Stitched edges for longevity
- Cloth surface, rubber base
- Machine washable
- Compact keyboard mat
- 4mm thick to absorb vibrations
- Creates muted acoustics
- Designed for GMMK Pro
- Fits most 75/65/60/40% keyboards
