There’s no better time to get started on those long overdue summer projects.
Instead of putting them off for much longer, we’ve put together this list of everything you need to get those projects ticked off your list.
PC Systems
If you’ve got giving your set up a much-needed upgrade on your list of summer projects – then you’re in luck. We’ve got a huge line up of pre-built and configurable PC systems that you can choose from, suitable for a range of budgets, and all packed full of powerful hardware to ensure you get the very best performance.
Our pre-built systems, such as the Refract Gaming range, have been tailored for specific gameplay styles and budgets, with six different PCs to choose from. Each system has been configured utilising cherry-picked hardware to ensure maximum performance at up to 1080p, 1440p, and 4K resolutions. What’s more, included with your Refract Gaming PC is a three-year warranty, which also covers parts and labour, for extra peace of mind in case of any repairs. Plus, they are even available for next-day delivery, so you don’t have to wait long to start playing all your favourite games.
Refract Gaming Jade Pre-built PC
- Pre-built gaming PC
- Designed for mid-tier gaming and budding content creation
- Includes an AMD Ryzen 7 7700 and NVIDIA RTX 4060 Ti
- 32GB DDR5 RAM
- 1TB M.2 SSD
Alternatively, you can opt for a configurable system. With a configurable PC, you can adjust the base hardware specification to ensure your new shiny system perfectly matches your individual preferences and gameplay style. You can make adjustments to the PC, including choosing the perfect chassis, upgrading the core components, opting for additional storage drives or Wi-Fi adapter cards, and even bundling your PC with a monitor and peripherals.
OcUK Gaming Tanto Configurable PC
- Configurable gaming PC
- As standard includes an AMD Ryzeen 7 7700X CPU and NVIDIA RTX 4060 Ti
- Up to 32GB DDR5 RAM
- Customisable case options
PC Components
Whether you want to build your own PC completely from scratch or your system is in need of a few component upgrades, we’ve got all the vital hardware you need.
This includes:
- Motherboards
- Processors
- Graphics Cards
- Power Supplies
- Memory
- Storage
- Adapter Cards
- Sound Cards
- Software such as operating systems
If you’re embarking on a mission to build the PC of your dreams this summer, then be sure to take a look at our ultimate PC Building Hub. In this in-depth guide, we take you through everything you need to build your system, from hardware to tools, along with all our top building tips.
Alternatively, there is also our Overclockers UK Academy, which has been crafted to answer every burning tech question you’ve ever had about your PC. Whether this is helpful advice on how to install your GPU or a step-by-step video and blog guide about fixing common PC issues.
Water Cooling
Is your gaming PC struggling with high temperatures? Why not consider upgrading to water cooling this summer?
Water cooling consists of several different components and a powerful liquid coolant, to draw away excess heat from vital hardware. This includes a:
- Pump: Circulates the liquid coolant throughout the loop
- Reservoir: Stores the coolant ensuring that there is always a consistent flow in the pump
- Water block: A type of heatsink responsible for transferring heat away from vital components.
- Radiator: Helps to dissipate any heat created by the coolant
- Fittings: Responsible for connecting all the tubing to your components
- Soft/Hard tubing: Connects all your chosen components together, allowing the liquid coolant to flow freely.
Alternatively, if you don’t want to install a hefty water-cooling loop, you also opt for an AiO CPU cooler instead. An AiO, or All in One, features all the same components, but are much easier to install.
Whether you opt for a complete loop or an AiO, water cooling boasts countless advantages to your PC. You can learn more about why you should opt for water cooling in our blog post.
Lian Li GALAHAD II Trinty AiO 240mm CPU Cooler
- AiO CPU cooler
- 240mm
- 2 x 120mm high-performance fans
- Integrated RGB lighting
- Compatible with LGA and AM5 sockets
Keyboards
No gaming set-up is complete without a high-quality keyboard, and that’s why there’s no better time than the present to upgrade your keyboard!
Available in different sizes, and armed with a multitude of key switches, mechanical keyboards come equipped with everything you need to enjoy superior gaming performance. This includes ultra-fast response times, a smooth typing feel, features such as anti-ghosting or N-key rollover, and of course that classic ‘clicky’ noise.
Most modern mechanical keyboards will utilise hot swappable technology, allowing you to freely swap and combine different key switches. You can customise your WASD or arrow keys with ultra-fast Cherry MX Speed Silver switches. Alternatively, if you like to take your keyboard into the office, why not customise it with virtually inaudible Cherry MX Silent Reds? You won’t have to worry about everyone’s favourite clicky noise interrupting your colleagues.
Ducky One ProjectD Tinker 65% Mechanical Gaming Keyboard
- 65% form factor
- Ducky ProjectD
- Pre-built mechanical keyboard
- Hot-swappable PCB
- PBT double-shot keycaps
Glorious GMMK 2 96% Mechanical Gaming Keyboard
- Mechanical gaming keyboard
- 96% form factor
- UK ISO layout
- Hot-swappable technology
- This model comes with Glorious Fox switches
- Double-shot keycaps
What’s more, if you want even more customisation and control over your peripherals, why not consider building your own mechanical keyboard this summer? Our Overclockers UK Academy has both a written and video guide to help you through the process!
Mice
Are you spending this summer perfecting your mouse movements to level up your gaming? Why not kickstart this project by upgrading your gaming mouse?
Typically, gaming mice have been designed with gamers and esports professionals in mind. As a result, they come packed with plenty of cutting-edge features to enhance your gaming performance. This includes lightweight construction, powerful optical sensors, customisable DPI settings, low-friction mouse feet, and much more. All of which combined results in enhanced precision and control
Glorious Model O USB Odin Gaming Mouse
- Optical gaming mouse
- Pixart PMW 3360 sensor
- Kalih Ormon mechanical switches
- Up to 12,000 DPI
- G-Skate mouse feet
Glorious Model O Wireless Gaming Mouse
- Wireless gaming mouse
- Glorious BAMF sensor
- Up to 19,000 DPI
- 71 hours battery life
- 2.4GHz wireless connectivity
Don’t know which key features to look out for when shopping for your new gaming mouse? Well, that’s where our dedicated guide to gaming mice comes in!
Streaming
Is kickstarting your streaming career on your list of summer projects?
Thankfully, we stock a range of premium quality streaming accessories from Streamplify. Including high-res 1080p webcams, crystal-clear cardioid microphones, plenty of ring lights to ensure you look your best, collapsible green screens, acoustic panels, and even USB hubs.
Streamplify CAM Full HD 1080p Webcam
- Full HD 1080p webcam
- Captures at 60 FPS
- All glass lens
- Integrated privacy slide
- Built-in dual microphone
Do you want to kickstart your streaming career but have no idea where to start? Our dedicated PC Streaming Hub is your one stop place for all our in-depth streaming guides, tips, and tricks.
Gaming Chairs
Enjoy ticking off your list of projects from the comfort of your very own gaming chair.
Available from premium brands such as noblechairs, Nitro Concepts, and ThunderX3, all of our gaming chairs have been precision built, utilising only high-quality materials. This includes durable bases, comfortable PU leather or fabric upholstery, along with plush cold foam padding. All of which keep you supported, cool, and comfortable for longer. What’s more, you can find special edition chairs sporting your favourite characters, and games.
noblechairs HERO ST Stormtrooper Special Edition Gaming Chair
- Officially licensed design
- HERO model
- Built from PU leather with cold foam upholstery
- Adjustable ergonomics
- 4D armrests
- White and black design
- Coloured decals to represent the Stormtrooper helmet and Imperial insignia
noblechairs EPIC Fallout Nuka Cola Special Edition Gaming Chair
- EPIC model
- Vibrant red design
- Embroidered Nuka-Cola styling
noblechairs LEGEND Black/Red/White/ Gaming Chair
- New redefined chair design
- Integrated lumbar support
- 4D armrests
- Black/red/white design
What are the key features to look for in your next gaming chair? What are all the different brands of gaming chairs available? Pillow set or no pillow set? All your burning gaming chair questions are answered in our dedicated guide.
Your Summer PC Projects?
Be sure to let us know all about your summer projects in the comments below.
*Prices correct at time of writing and PC specs are subject to change.
