Overclockers UK stocks a whole bunch of HYTE products and, in this article, we’re breaking down some of the coolest PC cases, fans, and AIO coolers you can get your hands on!
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/HYTE-Everything-You-Need-To-Know-WP-Vers-1024x1024.png)
Hi, I’m Rob, and I’m a massive HYTE simp… Cool, now we’ve got that warning out of the way, we can all stare longingly at one of the best brands on the market right now. I’m totally not biased or anything though, I swear.
Y60
HYTE cases exploded into the mainstream back in 2022 after the release of their incredible Y60 chassis. The internet fell in love almost immediately, praising the Y60’s unique tempered glass structure and sleek design.
- ATX case with bezel-less 3-piece panoramic tempered glass panelling
- PCIe 4.0 riser cable included for vertical GPU mounting
- Protective riser cable canopy for half-height PCIe cards behind vertical GPU
- Cold floor cooling utilising sweeping vents – eliminates hot spots
- Three pre-installed Flow FE12 fans on floor and rear of case
- Dual-chamber design for intelligent cable management
More than just a looker, the Y60 packs some pretty heckin’ cool features into its mid-tower chassis. There’s plenty of cable management space to be had in the rear compartment, and routing holes between the two chambers makes keeping your setup mess-free simple. What’s more, the included PCIe Gen 4 rise cable allows you to place your GPU front and centre for all those Instagram shots you’ll be taking. After all, it’s too pretty not to, right?
![Work From Home: The OcUK Way To Make The Most of Your Workspace](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/22222-1024x1024.jpg)
Looking for some inspiration for your own Y60 gaming setup? Check out this article with tips and tricks on how to make your home office rock!
Y70 Touch 🥺 (AKA the love of my life… Sorry Astarion)
Just when you think you’re out, they pull you right back in. An insanely popular mod for the Y60 since launch has been to install an aftermarket screen in the corner glass panel of the case. Quickly listening to the community, HYTE has one upped the Y60 hack many of us have come to love with an awesome new case.
The Y70 features an integrated 4K 60Hz touchscreen that looks incredible! What’s more, you can fully customise the display in the HYTE Nexus Software. The upgrades don’t stop there, either. In addition to the awesome touchscreen, there are all around improvements in design throughout the case.
- 4K 10-Point Multi-Touch Display: Experience a mesmerizing 14.1″ capacitive touchscreen with 1100 x 3840 (4K) resolution and a smooth 60Hz refresh rate. Unlock new possibilities with 10-point multi-touch capability, customizable through the HYTE Nexus software.
- Massive 4 Slot Vertical Graphics: Accommodate even the largest GPUs effortlessly. The package includes a luxury PCIE 4.0 x 16 riser with a colour-matched canopy for a seamless GPU installation.
- Ginormous Cooling Capacity: Stay cool with support for up to a 360mm long, 125mm thick radiator on the side, and an adjustable top bracket for another 360mm radiator (up to 68mm thick). The cold floor cooling system directs fresh airflow straight into the GPU.
Need Even More HYTE PC Cases?
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/Y40-1024x1024.png)
HYTE Y40 Mid-Tower ATX Case
- ATX case with bezel-less 2-piece panoramic tempered glass panelling
- Extensive ventilation throughout the chassis with dust filters
- Two pre-installed 120mm fans on floor and rear of case
- Dedicated space for intelligent cable management
- Available in Red, Snow White, Black, and White
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/Hyte-Revolt-3-Mini-ITX-Black-edited.png)
HYTE Revolt 3 Mini ITX – Black
- Mini-ITX PC case with integrated headset holder and handle
- Full-size GPU support in a vertical mount
- Downward facing motherboard for intelligent cable routing
- Hinged panel with mount for 280mm radiator
- Dedicated cooling channels for CPU and GPU
- Tool-less side panels for easy installation and upgrades
- Handle for easy carrying
- Available in White and Black
HYTE THICC
Damn, boi, you thicker than a bowl of oatmeal. A new addition to the HYTE lineup, these fans pack a serious punch thanks to their 32mm T H I C C design. The extra junk in the trunk allows the HYTE THICC FP12 fans to deliver a monstrous 105.8 CFM airflow and 8.14 mm-H2O static pressure, making them ideal for use on radiators. Keeping these THICC PC fans in line is the NP50 controller and Nexus Link Primary Node.
HYTE THICC Q60 AIO
As if the THICC fans weren’t enough, HYTE come out here with this sexual beast 😩. 240mm of white and black two-tone deliciousness. This AIO CPU cooler is perhaps the coolest cat on the HYTE block! It features two of our friends, the THICC FP12 fans, alongside an impressive 52mm thick radiator and 5-inch ultra slim IPS display. Oh, and of course, there is some spicy RGB for you to play around with.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/HYTE-THICC-Q60-AIO.png)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/HYTE-THICC-Q60-AIO-2.jpg)
The 5-inch display is kitted out with an impressive 720 x 1280p resolution and 60Hz refresh rate. And if that’s not enough to get your customising on, then there’s a 32-pixel qRGB array perfect for bringing your entire system to life with mesmerising depth and colour.
Hungry for more HYTE?
Don’t worry we’re thirsty for more as well. Let us know in the comments if you’re adding HYTE to your gaming setup this year.
