Everything You Need to Upgrade to the AMD Ryzen 7000 Series!
If you want to harness the power of the all-new AMD Ryzen 7000 series, then this is the guide for you!
Here at Overclockers UK, we’ve compiled everything you need into one handy article. This includes all the CPUs in the series, compatible AM5 motherboards, and coolers, along with the other essentials to create the perfect gaming PC!
The AMD Ryzen 7000 Series
Designed to deliver you outstanding performance, the latest generation of AMD CPUs comes fully equipped with an array of cutting-edge features.
The AMD Ryzen 7000 Series has been built based on ground-breaking Zen 4 architecture. Thanks to the brand-new design, these CPUs have been expertly engineered for gaming and content creation. Each of the four desktop CPUs in the series features an enhanced metal stack along with faster and smaller power transistors. What’s more, with a hefty data width, of up to 256-bit, enjoy ultra-fast speeds and image processing. Each of the four processors will also come armed with AMD RDNA 2. These graphics have been primed for optimum performance and improved energy-efficiency, thanks to the brand-new I/O 6nm die.
In addition to all of this, this line of CPUs is fully equipped to support the latest generation of technology, including DDR5 and PCIe 5.0. Along with an intelligent combination of integrated L1, L2, and L3 cache.
Your Guide to AMD Ryzen 7000 Series
For a closer, in-depth look at the AMD Ryzen 7000 series, check out our dedicated blog post!
The CPUs
There are numerous processors in the AMD Ryzen 7000 Series. We’ve listed all of them down below:
  • Ryzen 5 7600X
  • Ryzen 7 7700X
  • Ryzen 9 7900X
  • Ryzen 9 7950X
  • Ryzen 5 7600
  • Ryzen 7 7700
  • Ryzen 9 7900
  • Ryzen 7 7800X3D
  • Ryzen 9 79900X3D
  • Ryzen 9 7950X3D
Ryzen 5 7600XRyzen 7 7700XRyzen 9 7900XRyzen 9 7950XRyzen 5 7600Ryzen 7 7700Ryzen 9 7900Ryzen 7 7800X3DRyzen 9 7900X3DRyzen 9 7950X3D
Cores681216681281216
Threads8162432121624162432
Base Clock4.7GHz4.5GHz4.7GHz4.5GHz3.8GHz3.8GHz3.7GHz4.2GHz4.4GHz4.2GHz
Boost Clock5.3GHz5.4GHz5.6GHz5.7GHz5.1GHz5.3GHz5.4GHz5.0GHz5.6GHz5.7GHz
Cache38MB40MB76MB80MB32MB32MB64MB140MB140MB144MB
TDP105W105W170W170W65W65W65W120W120W120W
8Pack and AMD Ryzen 7000
For a closer look at the AMD Ryzen 7000 series, why not check our dedicated video? We sat down with legendary overclocker, 8Pack, and got his thoughts on these new CPUs.
What Do I Need to Upgrade My PC?
Motherboard:
In order to harness the power of the AMD Ryzen 7000 series, you will need a motherboard that has a compatible AM5 socket.  It’s important to note, that these CPUs now utilise an LGA socket instead of a PGA, meaning they will not work with previous generation motherboards.
ASUS ROG Strix B650E-E DDR5 ATX Motherboard:
  • ATX form factor
  • Compatible with AMD Ryzen 7000 series
  • AM5 socket
  • B650 chipset
  • DDR5 compatible
AM5 CPU Cooler:
These CPUs have a high TDP (Thermal Design Power), which means you need an efficient cooler that is compatible with the AM5 socket, to keep it performing at its best.
Lian Li Galahad II LCD 280mm AiO RGB CPU Cooler:
  • 280mm AiO CPU cooler
  • 2 x 140mm PWM fans
  • dRGB lighting
  • Compatible with AMD AM5 socket
DDR5 RAM:
Since the AMD Ryzen 7000 series only supports DDR5 RAM, you will need to upgrade to the latest standard.  In fact, AMD has also engineered intelligent AMD Expo technology, specifically for these CPUs. Expo has been designed to make overclocking simpler and more user-friendly. With compatible Expo RAM kits, you can unlock ultra-fast memory and buttery smooth frame rates in all your favourite games. To experience AMD Expo, you need to purchase a compatible Expo RAM Kit.
Please note, that these CPUs do not support DDR4 memory.
Corsair Dominator Platinum RGB Expo 32GB (2x16GB) DDR5 Dual Channel RAM Kit:
  • 32GB (2x16GB) RAM modules
  • DDR5
  • AMD Expo technology
  • 6000MHz RAM speed
  • Patented DHX cooling
The Other Essentials
The rest of your hardware will work just fine with the AMD Ryzen 7000 Series. With that said, why not upgrade a few other bits whilst you’re at it?
Graphics Card:
A powerful gaming PC is incomplete without a graphics card.
Sapphire Nitro+ Radeon RX 7800 XT 16GB GDDR6 Graphics Card:
  • AMD Radeon RX 7000 Series
  • AMD RDNA 3 architecture
  • 16GB GDDR6 video memory
  • VR ready
  • DirectX 12 support
SAPPHIRE NITRO+ AMD Radeon™ RX 7800 XT Gaming Graphics Card with 16GB GDDR6, AMD RDNA™ 3 architecture
Power Supply:
Supply all of your incredible gaming hardware with a reliable stream of power from a high-quality PSU.
Kolink Regulator 850W 80 PLUS Gold Modular Power Supply:
  • Modular form factor
  • 850W capacity
  • ATX 3.0 compatible
  • PCIe 5.0
  • 80 PLUS Gold rating
Storage:
Store all of your favourite games, music, videos, creative projects, and so much more on an ultra-fast Solid State Drive.
WD Black SN850X 1TB M.2 NVMe SSD:
  • 1TB capacity
  • 2280 form factor
  • PCIe 4.0
  • 7300MB/s read speed
  • 6300MB/s write speed
Don’t Want to Build Your Own?
Is building your own PC not quite your vibe? Our Refract Gaming Pre-built range harnesses the AMD Ryzen 7000 Series to power your favourite games and creative workloads like never before. Each one has been designed to suit a specific gameplay style and budget.
Refract Gaming Amber 2023
Refract Gaming Amber Pre-Built PC
  • Pre-built gaming PC
  • Designed for casual gaming
  • Includes an AMD Ryzen 5 7500F CPU and NVIDIA RTX 4060
  • Up to 16GB DDR4 RAM
  • 1TB M.2 SSD
Refract Gaming Jade Pre-Built PC
  • Crafted for mid-tier gaming and budding content creators
  • Includes an AMD Ryzen 7 7700 CPU and NVIDIA RTX 4060 Ti
  • Up to 32GB DDR5 RAM
  • 1TB M.2 SSD
Refract Gaming Jade 2023
Refract Gaming Celeste 2023
Refract Gaming Celeste Pre-Built PC
  • Engineered for mid-range gaming and streaming
  • Includes an AMD Ryzen 7 700X CPU and NVIDIA RTX 4070
  • 1TB M.2 SSD
Refract Gaming Azure Pre-Built PC
  • Designed for mid to high-level gaming and streaming
  • VR ready
  • Includes an AMD Ryzen 7800X3D CPU and NVIDIA RTX 4070 Ti
  • 1TB M.2 SSD
Refract Gaming Azure 2023
Refract Gaming Indigo 2023
Refract Gaming Indigo Pre-Built PC
  • Crafted for elite-tier gaming and high-quality streaming
  • Includes an AMD Ryzen 9 7900X3D CPU and NVIDIA RTX 4080 Super
  • 32GB DDR5 RAM and 1TB M.2 SSD
  • 1000W PSU
Refract Gaming Ultraviolet Pre-Built PC
  • Built for elite-tier gaming and high-quality streaming
  • Cherry-picked hardware
  • Includes an AMD Ryzen 9 7950X3D CPU and NVIDIA RTX 4090
  • 2 x 1TB M.2 SSD
Refract Gaming Ultraviolet 2023
Learn More About Your PC Hardware
Top Five AMD CPUs for Gaming – Available Right Now!
Will You Be Upgrading?
Will you be upgrading to the AMD Ryzen 7000 series? Have you already got your hands on one of the processors? Leave your thoughts in the comments below!
*Prices correct at time of writing and PC specs are subject to change.
0 0 votes
Article Rating
Subscribe
Notify of
guest
2 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
bob
bob
2 years ago
good
Emily Haylock
Editor
2 years ago
Reply to  bob
thank
