Is your gaming mouse looking a little old and tired? Fancy trying to win an ASUS ROG Keris II Ace Wireless Mouse?
This optical gaming mouse is packed with incredible features to optimise and boost your gaming performance. And we just want to give one away?! (Something, something, we’re all mad here!) Read on to learn more about the ASUS ROG Keris II Ace and the giveaway deets!
ASUS ROG Keris II Ace Wireless Gaming Mouse
The ASUS ROG Keris II Ace is a wireless gaming mouse that connects either via ROG SpeedNova 2.4GHz, Bluetooth, or USB-C to USB-A. Tri-mode connectivity, baby! This lightweight mouse is packed with features to enhance your gaming performance.
Thanks to the ROG Polling Rate Booster, you can enjoy polling rates up to 4,000Hz in wireless and 8,000Hz in wired mode. That is inputting data to your gaming PC up to eight times faster! Smooth. Paired with the ROG AimPoint Pro optical sensor that boasts up to 42,000 DPI, you’re going to leave your competition in the dust.
With its ergonomic shaping and 54g weight, the ASUS ROG Keris II Ace will remain comfortable under your hand, preventing fatigue in longer gaming sessions. It has been thoroughly tested by FPS esports pros, and they fully approve!
If you don’t fancy your chances, the ASUS ROG Keris II Ace Wireless is available to buy on the Overclockers UK website. Better yet, until September 23rd 2024, you can get cashback on this mouse as part of ASUS’ back to school deal! You better believe we got the buttons that take you to the right corners of our website.
The Giveaway
Now for the important giveaway details. By filling out the Gleam form, one lucky winner will receive the ASUS ROG Keris II Ace Wireless Gaming Mouse.
You have until September 20th 2024 to get your entries in! The winner will be picked and announced after the competition has closed.
Good luck, folks!
Overclockers UK Asus ROG Keris II ACE GiveawayIf the widget is not loading for you, you can also access the Gleam form here.
Unboxing
Like to see the ASUS ROG Keris II Ace in action one more time. Check out our unboxing TikTok!
Good Luck!
Best of luck to all those that enter! Let us know in the comments if all your fingers and toes are crossed.
