What’s better than a sprawling space RPG? A sprawling space RPG played on brand-new, shiny hardware! AMD and Starfield are talking our language.
![AMD Starfield bundle](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/amd-starfield-feature-1-1024x1024.jpg)
What is Starfield?
ICYMI, Starfield is an upcoming RPG from Bethesda. Promising interstellar gameplay like never before, there are more than a thousand diverse planets to explore, with bustling cities and vast landscapes just waiting for you. Work with Constellation, the last remaining space explorers, as you take on quests that lead you to the far reaches of the Settled Systems.
![Starfield is Coming](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/Starfield-blog-featuredimg-150x150.jpg)
Learn more about Starfield and what it requires from your gaming PC in our dedicated article.
The Deal
So, what is the deal? For a limited time, you can score a Starfield game key when you purchase select AMD products from Overclockers UK. This offer is available on AMD CPUs, GPUs, and full gaming systems.
To sweeten the deal further, depending on which model is purchased, you either get the Premium or Standard Edition of Starfield!
![Starfield header](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/starfield-lp-grab.png)
AMD Ryzen™ 9 7950X3D | AMD Ryzen™ 7 7800X3D |
AMD Ryzen™ 9 7950X | AMD Ryzen™ 7 7750X |
AMD Ryzen™ 9 7900X3D | AMD Ryzen™ 7 7700 |
AMD Ryzen™ 9 7900X | AMD Ryzen™ 5 7600X |
AMD Ryzen™ 9 7900 | AMD Ryzen™ 5 7600 |
AMD Radeon™ RX 7900 XTX | AMD Radeon™ RX 7600 |
AMD Radeon™ RX 7900 XT | AMD Radeon™ RX 6650 XT |
AMD Radeon™ RX 7800 XT | AMD Radeon™ RX 6600 XT |
AMD Radeon™ RX 7700 XT | AMD Radeon™ RX 6600 |
AMD Radeon™ RX 6950 XT | |
AMD Radeon™ RX 6900 XT | |
AMD Radeon™ RX 6800 XT | |
AMD Radeon™ RX 6800 | |
AMD Radeon™ RX 6750 XT | |
AMD Radeon™ RX 6700 XT | |
AMD Radeon™ RX 6700 | |
PC Systems with AMD Ryzen™ 5700G or AMD Ryzen™ 5 5600G and an AMD Radeon™ graphics card as listed above | |
PC Systems with an AMD Ryzen™ processor and AMD Radeon™ graphics card as listed above |
Shop CPUs
![AMD Ryzen 9 7000 Series X3D Cache CPU](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/amd-ryzen-9-7000-series-3d-v-cache-cpu-300x300.png)
Take advantage of 3D V-Cache with the AMD Ryzen 9 7900X3D CPU. Boasting twelve cores, twenty-four threads, and a whopping 140MB cache, this CPU is primed for Starfield. Built with AMD Zen 4 architecture, game on a five-star platform that has boost speeds up to 5.6GHz with support for DDR5 and PCIe 5.0. Plus, with a suite of AMD technologies and drivers, you can get the very best out of this processor.
Shop GPUs
Experience the stars in high resolution with smooth frame rates, thanks to the ASRock AMD Radeon RX 7900 XTX Taichi GPU. Built on RDNA 3 architecture, this graphics card is packed with a suite of innovative features to optimise your gameplay, such as AMD FSR and Infinity Cache technology. With boost speeds up to 2680MHz and 24GB GDDR6, this graphics card operates with great efficiency whilst you game and create.
![Asrock Radeon RX 7900 XTX Taichi OC 24GB GDDR6 PCI-Express Graphics Card](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/asrock-radeon-rx-7900-xtx-gpu-300x300.jpg)
Shop Systems
![OcUK Gaming Buzzard PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/02/ocuk-gaming-buzzard-pc-300x300.jpg)
Upgrade your whole system with the OcUK Gaming Buzzard Configurable Gaming PC. Equipped with your choice of AMD Ryzen 7000 Series CPUs and Radeon RX GPUs, you can craft this gaming PC into the perfect vessel for all your space adventures. Plus, with up to 64GB of DDR5 RAM with AMD EXPO and up to two high-speed SSD, you never need to worry about slow loading times and latency as you hop from planet to planet.
For full details on this incredible deal, head over to our dedicated page.
![AMD Starfield banner](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/07/amd-starfield-banner.jpg)
Are You Going to Upgrade for Starfield?
Are you counting down the days to this epic space RPG? Drop a comment below if you’re going to upgrade before it hits our gaming monitors.
