Are you looking to level up your gaming and upgrade your PC hardware? PCIe 5.0 might just be the answer you’re looking for, boasting incredible speeds and frequencies which are sure to boost your gameplay.
We’ve rounded up everything you need to know about PCIe 5.0 and how it can benefit your gaming adventures.
What is PCIe 5.0?
5.0 is the latest generation of PCIe, otherwise known as Peripheral Component Interconnect Express. PCIe 5.0 has been expanded to better enhance performance, delivering double the amount of bandwidth and frequency. Both of which make it even easier for you to enjoy blistering fast speeds in both gaming and streaming alike.
If you want to learn about what PCIe is and its vital role within your gaming PC, be sure to check out our ultimate guide.
How Does PCIe 5.0 Compare to Previous Standards?
There have been five generations of PCIe, each one improving on the limitations of its predecessor. Our handy table below highlights all the key differences between PCIe standards.
Generation | Bandwidth | Gigatransfer | Frequency |
PCIe 1.0 | 8GB/s | 2.5GT/s | 2.5GHz |
PCIe 2.0 | 16GB/s | 5GT/s | 5GHz |
PCIe 3.0 | 32GB/s | 8GT/s | 8GHz |
PCIe 4.0 | 64GB/s | 16GT/s | 16GHz |
PCIe 5.0 | 128GB/s | 32GT/s | 32GHz |
What Hardware Do You Need for PCIe 5.0?
Whilst PCIe 5.0 is backwards compatible with previous generations, to fully utilise this new standard, you will require a compatible motherboard. Without a 5.0 compatible motherboard as the centrepiece of your PC, you won’t be able to fully take advantage of the incredible speeds and frequencies of PCIe 5.0.
What Components Feature PCIe 5.0?
Once you have your compatible motherboard, you can find a range of modern-day components that feature support for PCIe 5.0. This includes:
- Processors
- Graphics Cards
- SSDs
- Power Supplies
Is PCIe 5.0 Good for Gaming?
PCIe 5.0 boasts countless benefits for gamers. With a PCIe 5.0 compatible GPU, you can unlock even smoother visuals and quicker response times in all your favourite games to boost your immersion one step further.
PCIe 5.0 SSDs boast blisteringly fast read and write speeds to facilitate quick data transfer rates and near-zero loading times. You can wave goodbye to waiting hours for your gaming worlds to load. All of which you can enjoy with minimal latency or lag for an optimised experience every time.
What’s more, with more manufacturers making the move over to PCIe 5.0, you can enjoy compatibility with a wide range of the latest hardware from Intel, AMD, and NVIDIA. This ensures you can continue to take advantage of cutting-edge tech to level up your performance even further.
Upgrade to PCIe 5.0!
Are you looking to upgrade to PCIe 5.0? At Overclockers UK, you can find plenty of premium gaming hardware that supports PCIe 5.0 to help level up your gaming.
We’ve rounded up a few of our fave PC essentials that are compatible with 5.0. This includes a motherboard, processor, graphics card, power supply, and SSD. Everything you need to kick your gaming adventures at blisteringly fast speeds.
AMD Ryzen 7 9700X Processor
- Socket AM5
- AMD Ryzen 9000 Series
- 8 cores
- 16 threads
- Up to 5.50GHz boosted clock speeds
- Supports PCIe 5.0
- 65W TDP
ASUS ROG Crosshair X670E Hero DDR5 ATXS Motherboard
- ATX form factor
- Supports AM5 socket
- DDR5 compatible
- PCIe 5.0
- Integrated Wi-Fi 6E
Zotac GeForce RTX 4070 Ti Super Trinty OC White 16GB GDDR6X Graphics Card
- Ada Lovelace architecture
- 8448 CUDA cores
- 2625MHz boosted clock speed
- 16GB GDDR6X video memory
- Compatible with PCIe 5.0
Crucial T700 2TB NVMe PCIe 5.0 M.2 SSD
- 2TB storage capacity
- PCIe 5.0 compatible
- 12,400MB/s read speed
- 11,800MB/s write speed
Kolink Regulator 1000W 80 PLUS Gold Modular Power Supply
- 1000W capacity
- 80 PLUS Gold rating
- Modular form factor
- ATX 3.0 compatible
- PCIe 5.0
Learn More About PCIe
How Has PCIe 5.0 Helped Your Gaming?
Have you upgraded to PCIe 5.0? How has it improved your gaming? Let us know in the comments.
