![Gaze into Eternity: The Kolink VOID RGB!](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/01/FB-EN-Kolink-VoidRGB-1-1024x1024.png)
Kolink is kicking off this year with a cracking range of cases. With the Big Chungus and the Quantum already unveiled in mid-January, Kolink is now following up this two-punch combo with the VOID RGB Midi-Tower as well as the KLM-002 mini. The VOID RGB Midi-Tower is a stand-out highlight, with its combination of modern design, a V-shaped infinity mirror with digitally addressable RGB lighting in the front.
Kolink VOID RGB Midi-Tower
The V-shaped cut-out in the front makes the Kolink VOID RGB case stand out from the crowd. It has an infinity mirror integrated into it which is then combined with digitally addressable RGB lighting. Needless to say, this unlocks a world of breath-taking effects. Yet the interior of the case includes even more lighting, including a 120 mm fan that comes preinstalled at the rear with its own dARGB lighting. The lighting on the front and the fan can be controlled either via the I/O panel or by using a compatible motherboard.
![Kolink Void RGB Midi Tower Case - Black Window](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/01/GEKL_063_01-300x300.jpg)
![Kolink Void RGB Midi Tower Case - Black Window](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/01/GEKL_063_04-300x300.jpg)
Furthermore, the case includes a tempered glass side panel to allow owners to enjoy an unobstructed view of the interior. This doesn’t interfere or mean any compromise on cooling however, due to the presence of large side-facing air inlets and a large mesh vent complete with dust filter on the top. Graphics cards can be up to 31 cm long, CPU coolers can be 16 cm tall and power supplies up to 18 cm long. The PSU shroud and the thoughtful case design also mean that owners will benefit from plenty of cable management options.
The Features of the Kolink Void at a Glance
- V-Shaped cut-out with infinity mirror effect and RGB lighting
- Tempered glass side panel for an unobstructed interior case view
- For motherboards in ATX-/Micro-ATX-/Mini-ITX formats
- A pre-installed 120 mm fan with dARGB lighting
- Support for radiators up to 240 mm at the front
- I/O Panel with 2x USB 3.0 & 2x USB 2.0, HD Audio, RGB-LED controller
- PSU shroud with air inlets for a clean look
- Graphics cards up to 310 mm, CPU coolers up to 160 mm, PSUs up to 180 mm
![Kolink Void RGB Midi Tower Case - Black Window](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/01/GEKL_063_06-300x300.jpg)
![Gaze into Eternity: The Kolink VOID RGB!](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/01/Teaser-EN-Kolink-VoidRGB.jpg)
Kolink KLM-002 Mini
The Kolink KLM-002 is a compact case that is primarily designed for use in office or home office environments. Depending on your space requirements, it can be used in either vertical or horizontal orientations and also offers space for small Micro-ATX motherboards as well as slots for up to three drives. The case is still spacious enough to house a low-profile graphics card with a maximum length of 15 cm. The use of a processor with integrated graphics is recommended. Despite the low price, the case manages to provide an aluminium-look front.
![Kolink KLM-002 Micro-ATX Desktop Case - Black/Grey](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/01/GEKL_058_01-300x300.jpg)
![Kolink KLM-002 Micro-ATX Desktop Case - Black/Grey](https://www.overclockers.co.uk/blog/wp-content/uploads/2020/01/GEKL_058_02-300x300.jpg)
The Features of the Kolink KLM-002 at a Glance
- Compact mini case 35.5 x 9.5 x 28.5 cm
- For motherboards up to Micro-ATX, processors with integrated GPU recommended
- Horizontal or vertical usage, stand included with case
- Slots for a 3.5- and 2.5” drive or up to three 2.5” drives
- A pre-installed 80 mm fan
- For SFX power supplies
- I/O Panel with 1x USB 3.0, 2x USB 2.0, Audio In/Out
