After the announcement of Nvidia’s latest RTX 3000 graphics on the 1st of September, the release date for the first Ampere powered graphics card is just around the corner. The RTX 3080 will be available on the 17th of September at 2 pm and if you want to be one of the first to get your hands on this powerful gaming GPU look no further than Overclockers UK. If you’re looking to upgrade your existing system you can purchase a solo RTX 3080 HERE starting at £649. However, If you’re not quite ready to build your own PC why not get yourself a custom PC assembled by one of the industries best PC builders. Overclockers UK has a range of prebuilt PCs available and several models have been updated with RTX 3000 graphics ready for launch day.
What makes Overclockers UK one of the best prebuilt PC builders?
- All of our machines come with a full three year collect & return warranty including parts and labour. We also offer a labour free upgrade service should you wish to upgrade your PC during the warranty period.
- We Aim that every order placed with us is built and configured within seven working days by our team of experts. (Please allow longer for Prestige Systems due to their complexity.)
- Using our custom-developed testing suite, every system undergoes a series of CPU, memory and graphics stress tests to ensure the reliability and stability of these critical components. Each system then performs a series of benchmarks to make sure it is at peak performance.
- Our in-house design/R&D team are able to offer a fully bespoke solution including custom water-cooling, case modification, lighting and cable braiding.
- You can choose from a range of delivery options including DPD next day and weekend delivery. A Contactless Click and Collect service is also available from our store.
Overclockers Germanium Z4 Overclocked RTX Gaming PC
The Germanium Z4 is the fourth generation of Overclockers best-selling gaming PC and it now comes with your choice of Ampers Nvidia RTX 3000 series graphics card for the latest and greatest graphics performance. The Germanium has been expertly assembled using high-quality Gigabyte Aorus components and a professionally overclocked 10th gen Intel processor for the perfect combination of flashy good looks and powerful performance. The RGB lighting is fully customisable and you can even specify a custom made lightbox to take the lighting to the next level.
Case: Phanteks Evolv X PC case, Phanteks P600 PC plus many more!
- Evolv X is a beautiful high-quality case that is available in three different colours. Choose from Black, Gunmetal grey or Galaxy silver.
- Evolv X has tinted left and right tempered glass side panels to showcase your components and outstanding cooling options and great airflow with mesh to prevent dust entry.
- The P600 is available in Black, white or gunmetal grey with a tempered glass side panel and optimised airflow for an attractive design with great cooling performance.
- The Overclockers UK build configurator allows you to also choose from a range of other cases so you can design your own PC.
Processor: Intel Core i9 10900K
- Flagship Intel processor with unbeatable gaming performance thanks to the high core count and clock speed.
- Has 10 Cores with hyperthreading for a total of 20 threads which results in better multitasking performance for demanding workloads like video editing and streaming.
- Comes Overclocked by our expert technicians to at least 4.9GHz across all cores and tested for stability to get the most from your processor without the need for expert knowledge.
- If you want to pair your RTX 3080 with a more affordable processor you can choose between the Intel i7-10700K or the Intel i5-10600K.
Graphics: Gigabyte Geforce RTX 3080
- You can choose between the Gigabyte Gaming OC which comes as standard or upgrade to the Master or Xtreme which come with a standout cooler design.
- The Gaming OC comes with the Windforce 3x cooling system, 4 years warranty and RGB fusion 2.0. Clock speeds are TBD.
- The Xtreme and Master feature advanced cooling from the Vapour chamber cooler with unique blade stack fans for better heat dissipation and 4-year warranty. Clock speeds are TBD.
- The RTX 3080 comes with Nvidia’s 2nd gen RTX architecture, 10GB of GDDR6X memory and 8704 CUDA cores for incredible performance in the latest games.
- More graphics options such as the RTX 3070 and RTX 3090 will be added when they become available.
Memory and Storage
- Get super-fast load and boot times thanks to the Samsung 970 Evo Plus 500GB M.2 NVMe drive. There’s also room for more storage on the Team Group Vulcan 1TB SATA 2.5″ Solid State Drive.
- All the memory you’ll need for gaming is handled by 16GB of DDR4 3200MHz Dual Channel RGB RAM.
- You can upgrade and customise the storage if you need more space on either drive.
- If you want more memory for demanding tasks or unlimited chrome tabs you can add up to 64GB on the Gigabyte Z490 Aorus Pro AX motherboard.
Where can you buy the RTX 3080 Germanium gaming PC?
The Germanium Z4 will be available to order from September the 14th when the RTX 3080 GPU’s become available for sale. We are expecting extremely high demand for these graphics cards so make sure you get your order in quickly. The Overclockers PC Builder will also be live on the Germanium Z4 page so you can see the full list of components available and create and configure your own Gigabyte Aorus custom-built gaming PC. Pricing for our choice of components will be £2699.99 but this will change depending on your chosen specifications. If you want to bookmark the page and get ready for the launch you can check out the Z4 Germanium HERE.
Overclockers Radiance Pro Gaming PC
The Radiance Pro is powered by Asus and is for gamers who demand the best. Asus is the world’s leading motherboard manufacturer and is well known for creating other complementary hardware for the gaming and enthusiast market. The radiance makes use of these high-quality components to ensure maximum reliability and great aesthetics. The OCUK Gaming Radiance uses Asus Aura Sync RGB lighting technology to offer a fully colour customisable gaming PC. This allows you to adjust the lighting and make it flash, breath and light the room with colour. The choice is yours and you can change it easily using the software as the components synchronise together.
Case: Lian Li ROG Edition PC-O11
- The PC-O11WGX is an evolved and updated version of the classic PC-O11 which has been tailored to meet the high standards required to carry the ROG Certified label.
- The case features engraved ROG styling and comes in a unique anthracite colour. The tempered glass side panel has a ROG Certified logo and is perfect for showing off your components.
- The layout is optimised for high-performance gaming PCs with improved airflow and spacing for liquid cooling radiators such as the AIO cooler in this system.
- The graphics card can be vertically mounted which is the best way to show off your brand new Asus RTX 3080.
- Cooled by the attractive and efficient Asus Ryujin AIO 360mm with OLED Display.
Graphics: Asus TUF GeForce RTX 3080
- You can choose between the Asus TUF which comes as standard or upgrade to the ROG Strix which comes with a standout RGB cooler design.
- The Asus TUF comes with an all-aluminium grey no-nonsense industrial shroud that will allow the GPU to easily fit into any setup with subtle customisable RGB lighting accents.
- The Asus Strix features advanced cooling and high-end components for quiet, cool and reliable performance.
Memory and Storage
- Get super-fast load and boot times thanks to the Samsung 970 Evo Plus 250GB M.2 NVMe drive. There’s also room for more storage on the Seagate 2TB 7200RPM Hard Drive.
- All the memory you’ll need for gaming is handled by 16GB of DDR4 3600MHz Dual Channel RGB RAM.
- There will be the option to upgrade and customise the storage depending on your needs and requirements.
- If you want more memory for demanding tasks or unlimited chrome tabs you can add up to 64GB on the Asus ROG Maximus XII Hero Z490 DDR4 Motherboard.
Where can you buy the RTX 3080 Radiance gaming PC?
The Gaming Radiance Pro will be available to order from September the 14th when the RTX 3080 GPU’s become available for sale. We are expecting extremely high demand for these graphics cards so make sure you get your order in quickly. The Overclockers PC Builder will also be live on the Gaming Radiance Pro page so you can see the full list of components available and create and configure your own Asus custom-built gaming PC. Pricing for our choice of components will be £2999.99 but this will change depending on your chosen specifications. If you want to bookmark the page and get ready for the launch you can check out the Gaming Radiance Pro HERE.
