Following last year’s successful release of the Glorious Panda switches, the acclaimed manufacturer now unleashes a wild cat into the fray.
Introducing the Glorious Lynx featuring a linear actuation offering both high levels of speed and accuracy.
![Glorious Lynx Switch close up](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/Glorious-GLO-SWT-LYNX-Product-Image-1-ns.png)
Ready for the hunt
Glorious Lynx switches are perfectly suited for FPS titles and provide a premium typing experience.
As we’ve come to expect from Glorious, they have gone above and beyond to create a high-quality product. From a stem and leaf sourced from Japan to a spring from Korea, these are among the most premium switches available on the market. The shell itself even comes in an mesmerising shade of light blue.
![Glorious Lynx Switch disassembled](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/Glorious-GLO-SWT-LYNX-Product-Image-3.png)
Compatibility – Don’t Sweat it
Glorious have also made compatibility and customisation a priority. Choose between pre-lubed or unlubed sets, which enables you to truly create the type of feel you crave. In a similar vein, the switches are compatible with any ‘+’ shell type, so there are a multitude of key caps to choose from.
Available for pre-order now in sets of 36.
Additional links
- Check out our write-up of the range of Glorious Keyboard accessories available – link
Glorious Lynx – Pre-Lubed
- Premium linear switches
- unique light blue colour casing
- + stem compatible
![](https://img.overclockers.co.uk/media/image/thumbnail/GAKC_198_01_750x750.jpg)
Glorious Lynx – Lubed
- + stem compatible
