![Model O banner](https://img.overclockers.co.uk/media/image/GGR_O_Banner1.png)
The Glorious PC Gaming Race Model O Gaming Mouse is a professional gaming mouse with a high-quality optical sensor from Pixart and six buttons. The sensor offers a very precise resolution of 12,000 DPI. The upper side of the Model O with its honeycombs is particularly striking. This significantly reduces the weight of the mouse to just 67 grams. In addition, they ensure well ventilated hands. The RGB LED lighting illuminates out the inner mechanics of the mouse. The durable Omron switches ensure the long life of the Glorious PC Gaming Race Model O Gaming mouse. And, of course, the mouse also impresses with excellent values such as 50G acceleration.
![Model O mice samples](https://img.overclockers.co.uk/media/image/GGR_O_Samples3.png)
The special feature of the Glorious PC Gaming Race Model O Gaming Mouse are the honeycombs on the top and also on the bottom. They reduce the overall weight of the mouse significantly. The honeycomb pattern not only gives the mouse a unique look, but also allows a view of the mechanics inside, which are set in scene by an adjustable RGB LED lighting. At the same time, they provide good ventilation of the hands.
![Model O close up](https://img.overclockers.co.uk/media/image/GGR_O_Close_UP.png)
The shape is designed for ambidextrous operation, with the hand resting on the mouse in as natural a position as possible, thereby reducing strain on the fingers when operating the keys and avoiding unnecessary movement. Long gaming sessions are therefore no problem thanks to the ergonomic shape of the Glorious PC Gaming Race Model O Gaming mouse. The side buttons are both located from the left side to keep the weight low.
The mouse is designed for very fast movements. This is also ensured by the large gliders made of Teflon, which ensure smooth movement, no matter on which surface the mouse is used. In addition, there is the braided cable developed by Glorious PC itself. It’s super flexible and light as if you were using a wireless mouse. All this makes the Glorious PC Gaming Race Model O Gaming Mouse the perfect gaming periphery.
