Eye strain is common among gamers or anyone who spends a lot of time in front of a screen. For years, GUNNAR has offered a solution to this with their range of high quality eyewear products.
Advanced filter technology
A significant cause of eyestrain is the “blue light” which is emitted by screens from televisions to monitors to mobile phones. Using advanced lenses GUNNAR glasses can filter out such harmful blue light, thereby reduced eye fatigue and related problems such as headaches.
Outstanding build quality
The new Lightning models come in three variants: GUNNAR, ESL and Rainbow 6-Siege. Irrespective of which model you purchase you can rest assured that you will be gaming in comfort. Not only due to the filtering properties of the lenses, but also due to the material used in the glass’s construction. These have been made to at once be durable and comfortable.
But they are also stylish. It is the frames that make the Lighting models unique. Their shape is reminiscent of a lightning bolt so they will look good even if you use them while streaming. In fact they are so stylish you may want to wear them outside, which is perfectly fine as they incorporate UV protection.
