VR headsets are like gym equipment; they’re magnets for sweat, fingerprints, and a prime breeding ground for germs. In this article, we’re covering everything you need to know to keep yours fresh, clean, and ready for action.
Why Bother with Regular Cleaning?
Clean VR gear isn’t just about hygiene. It’s about maximising immersion and extending your headset’s life. Dust and smudges can mess with the display clarity, and dirt buildup on lenses can lead to blurry images. I mean, do you really want to put a nasty, dusty, oily thing on your face for hours anyway?
Pre-Session Prep
A great simple way to start is to wash your hands. A quick wash keeps oils off your headset and reduces grime buildup, which is especially key if you’re sharing your VR headset with others.
Time for a quick wipe-down! Before and after each use, grab a dry microfiber cloth and wipe down the headset. This keeps dust off the lenses, preventing those annoying smudges that can ruin immersion. WARNING: Be gentle around the lenses. These can be very fragile, and a scratch will ruin your gaming experience. Avoid using any non-recommended cleaning solutions and refer to your headset’s manual for further guidance.
Deep Cleaning Your VR Headset
While keeping on top of your headset hygiene with a once-over before and after each session is great for maintenance, you’ll also want to do a deep clean every now and again.
Exterior Surface: Use alcohol-free anti-bacterial wipes for the outer parts (avoiding the lenses). Anything alcohol-based can be too harsh and might leave a residue that’s tough to get off later.
IT Dusters Pixel Perfect Screen Cleaner Wipes
PER-ITD-01956
£8.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETFacial Interface & Straps: If yours are detachable, go ahead and take them off to really get into all the nooks and crannies. Some fabric straps can even be hand-washed with mild soap and water – be sure to check your manufacturers’ guide first! Got a Silicone or replaceable foam cover? Even easier! Just give them a quick rinse and air-dry.
How To Keep Your VR Headset Clean Longterm
If you’re using your VR headset a lot or even passing it around to others at parties, it might be worth investing in a VR cover. These slip over the facial interface and make cleaning simple. Pop one on, and you can just swap out and wash as needed. For extra protection, consider lens protectors to prevent accidental smudges while in use and lens covers for added protection from the sun when your headset’s off-duty.
The daffodils have sprung, the promise of warmer weather is here, and we’ve got that itch to do some spring cleaning.
Time For A New VR Headset?
Okay so maybe your headset is past saving or hey maybe it’s just time for an upgrade. #TreatYoSelf. Overclockers UK has your back with a whole boat load of great VR ready gaming PCs, VR headsets, and more!
HTC VIVE PRO 2 Full Kit – HD VR Headset, Controllers, Base Stations
- Explore VR content in brilliant clarity and bring out the finer details with a combined 4896 x 2448 resolution.
- 120° horizontal field of view (FOV) expands your visual experience and better aligns with the human eye, letting you see more naturally.
- Stay in the moment with precision SteamVR™ Tracking that provides 360-degree coverage of your movement to the millimeter.
HTC VIVE XR Elite All-in-one XR and PC-VR Gaming System
- Convertible form factor. Detach the battery cradle for enhanced portability.
- Vivid passthrough. Blend physical and virtual worlds. Expand play. New possibilities.
- Lightweight XR. A sleek, compact headset that goes where you go.
- Finely tuned viewing. Adjustable IPD and diopter dials for the most natural and clearest visual experience.
At Overclockers UK, we have our exciting range of pre-built PCs – Refract Gaming – and they have been updated with shiny new tech!
OcUK Gaming Empath – AMD Ryzen 7 7700X, RTX 4070 Gaming PC
- AMD Ryzen 7 7700X Eight Core Processor with 5.4GHz Boost
- 32B DDR5 5600MHz Dual Channel Kit
- Nvidia GeForce RTX 4070 12GB Graphics Card
- 2.5Gb LAN, WIFI 6 & Bluetooth
- Ideal For VR Gaming
Ready To Game?
Now your headset is nice and sweat-free, how about we make it all dirty again? The Overclockers UK Blog has a huge selection of VR game reviews, news, and more. If you’re looking for a game to play right now, be sure to check out our Coming To VR series, and for literally everything else VR we’ve got you covered with The Ultimate Guide to VR Gaming.
