Have you recently spoilt yourself with a brand-new wireless headset but are now stuck on how to connect it to your PC? If this is you – then fear not! There’s no time to panic since we’ve put together this helpful guide showcasing how you can connect your wireless headset to your gaming PC.
Why Buy a Wireless Gaming Headset?
Wireless gaming headsets are a must-have peripheral for anyone wanting to enjoy clutter-free, versatile gaming.
Completely wireless, you won’t need to worry about unnecessary cables cluttering up your desk, getting tangled in wires during intensive gameplay, or being tethered to your desk. In need of a midnight snack during a gaming marathon with the squad? Well, you can just get right up, headset still on, and wander to the fridge to pick out the ultimate gaming snack.
What’s more, your wireless headset can go anywhere with you. Whether you’re commuting to work and want to listen to your favourite gaming soundtracks on-the-go, or packing up your set up for a LAN session with the squad – a wireless gaming headset can go anywhere!
Advantages
- No cables cluttering up your space or getting tangled
- Portability – easy to take on-the-go with you or even wear around the house
Disadvantages
- Can have problems with sound quality and connectivity issues
- Typically more expensive than wired
- Often more complicated to use – requires more steps to configure and plug in
- Battery life – can be hit or miss
How to Connect via Bluetooth
In Windows, to connect your wireless headset via Bluetooth, you will need to go into Settings > Bluetooth & Devices > then turn on Bluetooth.
Once you’ve turned on your PC’s Bluetooth, you will then need to turn on your wireless headphones to make it discoverable. We recommend you check the manufacturer’s guide or website for the specific steps you need to follow in order to make your headset discoverable.
Once your headset is discoverable, locate the tray of icons on your task bar, usually near the time and date. From here select > the Network, Sound or Battery icon > Manage Bluetooth devices > select your chosen device under Not paired.
How to Connect via 2.4GHz Wireless
Certain wireless headsets come equipped with a 2.4GHz dongle. This will typically require a USB port.
To connect your headset via the 2.4GHz wireless, you will first need to ensure you plug the dongle into your PC via a spare USB port. Once you’ve done this, in Windows, you’ll receive a pop-up box saying that your wireless headset is ready to use – and that’s it!
Our Top Wireless Gaming Headsets
ASUS ROG Delta S Wireless Gaming Headset:
- Wireless
- 50mm ASUS Essence drivers
- AI Beamforming microphone
- 2.4Hz and Bluetooth connectivity
- Up to 25 hours of battery life
ASUS TUF Gaming H3 Wireless Gaming Headset:
- Wireless
- 7.1 surround sound
- Lightweight design
- 2.4GHz connectivity
- Up to 15 hours of battery life
Corsair Virtuoso White Wireless Gaming Headset:
- Wireless
- 50mm neodymium speaker
- Professional-grade microphone
- Corsair Slipstream wireless technology
- Up to 20 hours of battery life
- Lightweight and ergonomic design
Do You Have a Wireless Headset?
Do you use a wireless headset? Be sure to let us know in the comment section below whether you prefer wireless or wired and how its improved your performance or optimised your set up.
