HYTE is back to revolutionise gaming rigs, and I’m so here for it. Whether you’re building from scratch or looking to upgrade, their killer ecosystem makes it easier than ever to craft a jaw-dropping set-up. In this article, we’re exploring the dream team with the HYTE Y40 panoramic PC case and HYTE Q60 THICC AIO cooler.
What Makes HYTE Tick?
It’s no secret I’m a certified HYTE simp, but can you really blame me? HYTE made a massive splash in 2022 with the launch of their groundbreaking Y60 chassis. The internet fell in love almost immediately thanks to the case’s unique design and impressive cooling. Following on from the Q60, they’ve designed an ecosystem that makes customising your build intuitive and fun. At the heart of HYTE’s ecosystem is the Nexus software, which synchronises cooling, RGB, and more for a seamless custom PC building experience.
Overclockers UK stocks a whole bunch of HYTE products and, in this article, we’re breaking down some of the coolest PC cases, fans, and AIO coolers you can get your hands on!
The HYTE Y40: Built to Impress
If you’ve ever dreamed of a panoramic PC set-up, the Y40 PC case is your dream come true. Much like its big brother, the Y60, the Y40 is designed to showcase your build with dual tempered glass panels that offer an uninterrupted view of your internals.
More than just a pretty face, the Y40 is built for high-performance gaming PCs. It includes a PCIe 4.0 riser cable for vertical GPU mounting, plus ample room for up to seven fans and radiators up to 360mm in length. There’s also dedicated space for cable management, keeping long cables hidden and improving airflow.
- GPU Placement Made Easy: Thanks to the included PCIe Gen 4 riser cable, you can mount your GPU vertically and flex your hardware.
- Optimised Cooling: Space for up to seven fans with two pre-installed or a 360mm radiator means the HYTE Y40 stays cool even during extended gaming sessions.
- Awesome Airflow: With rear cable management and intuitive routing holes, keeping things neat is simple.
HYTE Y40 Mid-Tower ATX Case – Black
CA-00C-HY
£139.99 £ 119.99
-14.29%(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKETHYTE Y40 Mid-Tower ATX Case – Snow White
CAS-HYT-00734
£139.99 £ 119.99
-14.29%(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKETHYTE Y40 Mid-Tower ATX Case – Red
CA-00E-HY
£139.99 £ 119.99
-14.29%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETIlluminate Your Y40
If you’re looking to take your new gaming PC to the next level, the HYTE LS10 and LS30 LED strips and NP50 Nexus Portal are the perfect addition. These are not your grandad’s LED strips; they offer vibrant lighting thanks to their 24-bit colour depth. Both the LS10 and LS30 offer exceptional lighting for your PC, with the latter being larger and great for bold lighting, whereas the LS10 is a great choice for more subtle effects and smaller cases. Thanks to Nexus Link and the powerful NP50 hub, you can sync and control everything from lighting to cooling with up to 54 devices across three channels.
HYTE LS10 LED Strip 3 Pack With NP50
COO-HYT-01525
£59.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETHYTE LS30 LED Strip 2 Pack With NP50
COO-HYT-01527
£64.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETHYTE Q60 AIO Cooler: Chilling in Style
Just like me, the HYTE Q60 is THICC with two C’s. *slaps top of Q60 This bad boi can fit so much cooling inside of it. HYTE’s Q60 AIO redefines performance, aesthetics, and customisation with incredible cooling potential and stunning visual appeal.
Packed with advanced cooling tech, the Q60 boasts a 240mm radiator and a 52mm thick heat exchanger to keep your CPU cool even under intense loads. This compact powerhouse features dual harmonic pumps, which operate between 2,000 – 4,500 RPM, ensuring high efficiency with minimal noise. What’s more, the 32mm THICC FP12 fans are crafted from fibreglass-reinforced Liquid Crystal Polymer, delivering impressive airflow of 105.8 CFM and static pressure up to 8.14 mm-H2O! Which if you don’t speak cooling nerd means they are ideal for radiators and provide ample cooling with little noise.
The Q60 doesn’t just keep your system cool, it turns heads while doing it! Kitted out with a 5-inch Ultraslim IPS display, you’re able to showcase your temps, the time, what you’re listening to, and more with custom backgrounds, gifs, and videos. Notably, the Q60’s screen features a 42-pixel qRGB array to add dynamic glow, saturating your rig with stunning, customisable lighting effects. The screen even rests on a Double-Hinged Floating Spout, which gives you 90 degrees of adjustable swivel, meaning you can make sure the screen faces you.
- 5-inch Ultraslim IPS Display: 720 x 1280 resolution (293 PPI), 60Hz refresh rate for crisp visuals.
- 42-Pixel qRGB Array: Bring your system to life with vibrant, customisable lighting.
- Dual Harmonic Pumps: Adjustable 2,000 – 4,500 RPM for efficient, quiet cooling.
- 52mm Thick Heat Exchanger: 240mm radiator with dual-pass design for optimal thermal performance.
- 32mm THICC FP12 Fans: Supercharged Fiberglass Liquid Crystal Polymer blades for 105.8 CFM airflow.
- Nexus Link Ecosystem: Supports up to 34 devices with sequential lighting and cooling control.
- Adjustable Display: 90-degree swivel with a Double-Hinged Floating Spout for easy positioning.
HYTE THICC Q60 240mm LCD All In One CPU Liquid Cooler – White/Black
COO-HYT-01514
£329.99 £ 219.95
-33.35%(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKETTruth be told, I like the Q60 so much I committed a devious lick and ‘borrowed’ OcUK’s sample to secretly install in my personal rig.
Control It All – HYTE Nexus
HYTE Nexus brings next-level control and connectivity to your PC set-up. Constantly being updated with new features, the HYTE Nexus app allows you to do just about anything! With Nexus, you can synchronise your system’s aesthetics, monitor performance, and even track thermal stats, all from one convenient interface.
Ready To HYTE up Your Cooling?
With the HYTE Q60, you get top-tier cooling, bold aesthetics, and unrivalled customisation, all in one sleek package. There’s no better place to put this legendary cooler than inside the exceptional HYTE Y40 for the ultimate powerhouse gaming PC. Make sure to let us know your thoughts on this combo in the comments.
