Cryorig – Efficient Cooling Solutions & Innovative Ideas
The team behind the relatively young company, Cryorig, consists of experienced cooling specialists and overclocking experts whose declared aim is to develop the highest performing products for fans of modding. Cryorig quickly made a name for themselves with their innovative solutions, and creating these solutions meant not just relying on high-quality materials, but also combining existing components in new ways so as to get the most out of them e.g. adding additional fans to CPU watercoolers. Cryorig also places an emphasis on making CPU cooler installation as simple and straightforward as possible. Finally it goes without saying that Cryorig focuses on getting the fundamental designs to be the best they can be.
High-Performance CPU Coolers Thanks to Cryorig’s Special Fin Design
CPU coolers from Cryorig are defined by their especially innovative fin design. Their Jet Fin Acceleration System comprises a compressed style of airflow to enable waste heat to be transferred away from components more quickly and efficiently. The heatpipes are integrated with the fins by means of a special soldering process. The increased contact area between heatpipes and fins result in a marked increase in heat transfer. Finally Cryorig’s high-performance fans are added into the equation to ensure not just quiet but also extremely effective cooling.
High-End CPU Cooler
High-End CPU Cooler:
  • Dual-tower cooler R1 Universal: 250 Watt TDP
  • Dual-tower cooler R1 Ultimate: 240 Watt TDP
  • Tower-cooler H5 Universal: 160 Watt TDP
  • Tower-cooler H5 Ultimate: 180 Watt TDP
  • Tower-cooler H7: 140 Watt TDP
Counting among the most eye-catching members of the line up must surely be Cryorig’s H7 Quad Lumi CPU Tower Cooler with its LED lighting and 160 Watt TDP.
Mid-Range CPU Cooler:
Cryorig's Low-Profile CPU Cooler Cryorig's Mid-Range-CPU Cooler
  • Tower-cooler M9i for 120 Watt TDP processors from AMD
  • Tower-cooler M9a for 120 Watt TDP processors from AMD
Low-Profile CPU Cooler:
  • Low-profile C1 with 140 Watt TDP
  • Mini top-flow C7 with 100 Watt TDP
Maintenance-Free Complete CPU Watercooling Solutions
Complete Watercooling Solutions
Full watercooling setups are characterised by high-performance components and unusual approaches. Take Cryorig’s reliance on the proven pump and copper base plate from Asetek and their addition of their own premium products to the equation in order to create high-performance All-in-One CPU watercooling solutions that not only allow for a notable extension in the lifespan of overclocked processors but also run maintenance-free while being easy to install to boot.
All-in-One-CPU Watercooling:
  • A40: 240 mm radiator with 27,5 mm height
  • A40 Ultimate: 240 mm radiator with 38,5 mm height
  • A80: 280 mm radiator with 27,5 mm height
Cryorig has just one more thing to add, in the most literal sense: An additional fan is included on the CPU heatsink to cool the air surrounding the CPU. The orientation of the fan can be changed in order to target hot spots e.g. around the RAM, graphics card or VRMs.
High-Performance and Quiet: Premium Fans from Cryorig
Cryorig takes a similar approach to their fans, emphasising high performance alongside low noise levels. For that reason Cryorig has opted for their own custom developed bearings named HPLN (High Precision Low Noise), in addition to the rubber spacers, to ensure particularly quiet operation.
Cryorig's Fans
Fans from Cryorig:
  • Cryorig QF120 Performance:
    120 mm fan with 600-2.200 RPM and 13 ~ 37 dB(A)
  • Cryorig QF120 Balance:
    120 mm fan with 330-2.200 RPM and 10 ~ 25 dB(A)
  • Cryorig QF120 Silent:
    120 mm fan with 200-1.000 RPM and 5 ~ 19 dB(A)
  • Cryorig QF140 Performance:
    140 mm fan with 600-1.850 RPM and 13 ~ 38 dB(A)
  • Cryorig QF140 Silent:
    140 mm fan with 200-1.000 RPM and 9 ~ 19,5 dB(A)
  • Cryorig XF140:
    25,4 mm thick 140 mm fan with 700-1.300 RPM and 19 ~ 23 dB(A)
  • Cryorig XT140:
    13 mm thick 140 mm fan with 700-1.300 RPM and 20 ~ 24 dB(A)
Premium Cryorig Accessories
Cryorig's Accessories
Cryorig’s reputation for quality also extends to their range of accessories, with their special high-performance thermal paste the company has achieved superb values in both thermal conductivity and thermal resistance. Last but not least Cryorig has also prepared all of their CPU coolers for the new AM4 socket by offering the requisite AM4 mounting kits.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
