Intel 12th Gen CPUs: Best Bang for Your Buck
Struggling to find your next great value CPU upgrade? Enter the Intel 12th Gen. Although slightly older, this generation of processors are still super powerful and come equipped with everything you need to boost your gaming to new heights. All without breaking the bank.
We’re showcasing everything you need to know about Intel 12th Gen processors, showcasing each model, and why they are perfect for gaming.
Keep on reading for more!
The Intel 12th Gen
The Intel 12th Gen, or Alder Lake, processors are the first generation of CPUs to feature Intel’s ground-breaking hybrid core architecture. Engineered with a combination of premium P-(performance) and E-(efficiency) cores, Intel 12th Gen CPUs have been optimised for seamless multitasking. The P-cores are responsible for squeezing every drop of performance possible from your processor, whilst the E-cores ensure peak efficiency across all your applications, no matter how demanding they are.
This is backed up by Intel Thread Director, a dedicated AI software which intelligently manages all your workloads, guaranteeing that the best core is assigned to the job. What’s more, these processors are compatible with plenty of the most popular standards including DDR4, DDR5, and PCIe 5.0
The CPUs
There are a range of Intel 12th Gen CPUs ranging from entry-level models all the way to flagship CPUs that are unlocked for overclocking. We’ve broken down all the processors in the Alder Lake generation split across the i9, i7, i5, and i3 models.
Core i9
  • 12900KS
  • 12900KF
  • 12900
  • 12900F
Core i7
  • 12700K
  • 12700KF
  • 12700F
Core i5
  • 12600K
  • 12600KF
  • 12500
  • 12400
  • 12400F
Core i3
  • 12300
  • 12100
  • 12100F
If you want a closer look at the key differences between these processors, look at our table below.
CoresThreadsBase ClockBoost ClockTDP
Intel i9 12900KS16243.4GHz5.5GHz150W
Intel i9 12900KF16243.2GHz5.2GHz125W
Intel i9 12900F16242.4GHz5.1GHz65W
Intel i9 1290016242.4GHz5.1GHz65W
Intel i7 12700KF12203.6GHz5.0GHz125W
Intel i7 12700K12203.6GHz5.0GHz125W
Intel i7 12700F12202.1GHz4.9GHz65W
Intel i5 12600KF10163.7GHz4.9GHz125W
Intel i5 12600K10163.7GHz4.9GHz125W
Intel i5 125006123.0GHz4.6GHz65W
Intel i5 12400F6122.5GHz4.4GHz65W
Intel i5 124006122.5GHz4.4GHz65W
Intel i3 12300483.5GHz4.4GHz60W
Intel i3 12100F483.3GHz4.3GHz58W
Intel i3 12100483.3GHz4.3GHz60W
Processor Chip Type
Intel CPUs are split into different categories and performance brackets based on the suffix in each name – KS, KF, K, or F
KS
‘KS’ processors have been built to perform at exceptionally high clock speeds, featuring support for overclocking. As a result, these processors often boast a higher than average TDP.
KF
‘KF’ CPUs feature the high specification of the standard ‘K’ models with no integrated graphics.
K
Intel 12th Gen ‘K’ CPUs are unlocked for overclocking, include onboard graphics, and boast notably higher base and boost clock speeds. These processors are the ultimate upgrade for gamers and streamers, but they demand extra power to deliver such high levels of performance. These models also feature onboard graphics.
F
Lastly, ‘F’ models all feature the same specification as the non-F models, but don’t include any onboard graphics. This means you will need a dedicated GPU to render the latest games.
HX Mobile Processors Explained
Are Intel 12th Gen CPUs Good for Gaming?
Intel 12th Gen CPUs have been fine-tuned to deliver peak performance and immersive gameplay in all your favourite AAA titles. The hybrid blend of P- and E-cores take control of processing your gaming worlds whilst also enhancing efficiency for fast clock speeds and near zero latency. All of which allows you to dominate your in-game enemies and simultaneously chat with your teammates with ease.
What’s more, compatibility with DDR4, DDR5, and PCIe 5.0 ensures you can use an Intel 12th Gen CPU with plenty of the latest hardware, including the NVIDIA RTX 40 and AMD Radeon RX 7000 Series. This means you don’t need to spend extra on upgrading the rest of your components to ensure you can fully utilise your new shiny Intel 12th Gen processor.
With models suitable for every budget and gameplay style, you are sure to find the perfect Intel 12th CPU to match your needs. All without breaking the bank.
Which Intel 12th CPU is Good For…
If you don’t know which Intel 12th Gen CPU is right for your set-up and needs, we’ve got your back! We’ve broken down our top recommendations based on casual, mid-tier, and high-end gaming.
Casual Gaming
For casual gaming, the Intel Core i5 12400F CPU is the perfect choice. Equipped with 6 cores and 12 threads, this processor features all the power you need to enjoy playing titles such as Overwatch 2, Stardew Valley, and more. With boosted clock speeds of up to 4.4GHz, enjoy ultra-fast performance across all your workloads, whilst PCIe 5.0 ensures minimal latency or input lag for uninterrupted gameplay every time. Plus, with a low TDP of only 65W, the i5 12400F is ideal for those looking to design a wallet friendly PC that is easy on the environment.
  • 6 cores
  • 12 threads
  • 4.4GHz boosted clock speeds
  • 65W TDP
Mid-tier Gaming
Alternatively, for mid-tier gaming, we recommend the Intel Core i7 12700KF. This processor is the ultimate upgrade for mid-tier gamers looking to notably boost their performance. Harnessing the combination of 12 cores and 20 threads, along with 5.0GHz boosted clock rates, unlock blisteringly fast speeds and seamless multitasking. You can stream, chat away to your friends, and play popular titles such as Zenless Zone Zero or Manor Lords.
Intel Core i7-12700KF CPU
Intel Core i7 12700KF CPU
  • 12 cores
  • 20 threads
  • 5.0GHz boosted clock speeds
  • 125W TDP
High-End Gaming
Last, but certainly not least, is the Intel i9 12900KF. This flagship tier processor features everything you need to immerse yourself fully in all your favourite AAA games including Elden Ring Shadow of the Erd Tree and Ghost of Tsushima. The hybrid core architecture with 16 cores and 24 threads can effortlessly handle any demanding task you throw its way with peak efficiency. All of which is backed up by Intel Thread Director.
Intel i9 12900KF CPU
  • 16 cores
  • 24 threads
  • 5.2GHz boosted clock speeds
  • 125W TDP
Intel Core i9-12900KF processor
Inspired to Upgrade?
Have we finally tempted you enough to upgrade to the Intel 12th Gen Series? If so, at Overclockers UK, you can find an extensive range of these incredible processors. Simply click the button below to browse our Alder Lake line-up.
Don’t Want to Build Your Own?
If building your own PC isn’t quite your vibe, don’t worry! You can find plenty of high-quality PCs that harness an Intel 12th Gen CPU.
OcUK Gaming Carbide Pre-Built PC
  • Pre-built gaming PC
  • Intel Core i5 12400F CPU and NVIDIA RTX 4060
  • 16GB DDR4 RAM
  • 1TB M.2 SSD
OcUK Gaming Carbide - Intel Core i5 12400F, RTX 4060 Pre-Built Gaming PC
OcUK Gaming Graphite - Intel Core i7 12700KF, RTX 4060Ti Pre-Built Gaming PC
OcUK Gaming Graphite Pre-Built PC
  • Intel Core i7 12700KF CPU and NVIDIA RTX 4060 Ti
  • 16GB DDR4 RAM
  • 1TB M.2 SSD
Do You Have an Intel 12th Gen CPU?
Do you have an Intel 12th Gen processor? How has this CPU improved your gaming performance? Tell us in the comments below.
*Prices correct at time of writing and PC specs are subject to change.
0 0 votes
Article Rating
Subscribe
Notify of
guest
2 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
John Taylor
John Taylor
3 months ago
Currently rocking a i9 1200f and my system is super fast with no bottle neck in gaming. This CPU is 65w so paired with my AIO it keeps super cool not going above 35 degrees in windows and never hits 60 degrees during any game session.
Highly recommend this CPU is you’re using a GPU and don’t care about overclocking.
Emily Haylock
Editor
3 months ago
Reply to  John Taylor
