AMD. Intel. Ryzen? Arrow Lake! Let’s face it, CPUs are heckin’ confusing. We’re breaking down everything you need to know to make an informed decision.
![Intel vs AMD: Which CPU Should You Choose?](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/amd-vs-intel-square-1024x1024.png)
Making the right decision for your new gaming PC can be hard. Should you choose Intel or AMD? Don’t panic, we’ve got all the deets you need. Here’s everything you need to know from architecture to pre-build AMD and Intel gaming PCs.
Intel Processors
Intel Core Ultra 200 Series is Intel’s latest range of processors, offering exciting new features for gamers to sink their teeth into. Arrow Lake CPUs are designed to take full advantage of Windows 11, utilise hybrid core architecture, support next-gen technology, and have a dedicated NPU for AI acceleration.
Hybrid Architecture & Enhanced Tech
Hybrid architecture was introduced in the Alder Lake generation, and then advanced for Raptor Lake, Raptor Lake-S, and Arrow Lake. It harnesses two different types of processing cores. The P-core is designed for single-thread, high-frequency performance. This core handles the majority of the workload.
The E-core is designed to spread background tasks across multiple cores and threads, maximising efficiency. Notably, this helps to conserve power when the performant cores are not needed, with a massive 40% improvement over Sky Lake Intel CPUs. This core also works alongside the P-cores to provide extra performance in applications that require it.
What sets Intel Core Ultra 200 apart from the previous desktop CPU generations is the inclusion of an NPU. This is a neural processing unit, designed to make quick work of AI tasks. It takes away the extra strain AI can cause on your CPU and GPU, making everything work just that bit smoother. You’ll enjoy improved in-game performance because of it!
This latest generation supports a whole host of modern tech, including DDR5 memory, PCIe 5.0, and the latest WiFi standards.
![DDR4 vs DDR5](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/12/ddr4vsddR5-blog-150x150.jpg)
Discover what you need to know about the differences between DDR4 and DDR5 RAM.
Which Intel CPU should I choose?
Intel Core CPUs come in four main tiers – i3, i5, i7, and i9 – while Core Ultra processors currently only come in three – Ultra 5, 7, and 9. These CPUs differ in performance and price – generally, the higher the number, the better the performance. There are also F, K, and KF variants which indicate whether the CPU is overclockable and whether it has integrated graphics.
Intel Core Ultra 9 is the most powerful CPU of the series, boasting twenty-four cores and boost speeds up to 5.7GHz. Between the hybrid core architecture and the NPU, this processor can effortlessly handle all your heavy workloads, from 4K gaming to live streaming the latest AAA games.
Like its Core i7 counterpart, the Ultra 7 is perfect for gamers who want to get the most out of their favourite titles. Leveraging twenty cores and threads with boost speeds up to 5.5GHz, these processors can seamlessly handle gaming, streaming, and content creation.
For mainstream gamers, the Ultra 5 offers a great balance of performance and budget-friendly pricing. You can enjoy all the latest innovations without breaking the bank!
Designed for pure power, the Core i9 will have the highest number of cores and threads, with 14th Gen featuring up to 24 and 32, respectively. What’s more, they’ll have the highest boost clock speeds, the i9-14900KF can reach a whopping 6.0GHz! This processor is perfect for creators who need to both game and stream, or creative types utilising hyperthreading and high core counts.
The Core i7 is a great choice for gamers demanding great performance in games and creator apps. Raptor Lake-S i7 processors feature up to 20 cores (28 threads), a base clock of 3.4GHz, max boost of 5.6GHz using Turbo Boost Max 3.0, and up to 125W TDP.
Intel Core i5 CPUs are designed to be the mainstream gaming sweet spot. 14th Gen can feature up to 14 cores (20 threads), a base clock of up to 3.5GHz, max boost of up to 5.3GHz using Turbo Boost 2.0, and up to 125W TDP.
The Intel Core i3 is all about entry level gaming whilst still providing optimised performance. 13th Gen offers up to 4 cores (8 threads), a base clock of up to 3.4GHz, and a max boost of up to 4.5GHz. This tier is perfect for playing older games, media consumption, and internet browsing.
Learn more about the latest Intel Core Ultra processors with our resident champion overclocker, Ian “8Pack” Parry.
Looking for a Pre-Built Intel Gaming PC?
We’ve been expecting you, Mr. Bond. Overclockers UK has a whole host of Intel-based gaming PCs.
![OcUK Gaming Eagle - Intel Core i9 14900KF, AMD Radeon RX 7900 XTX Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/06/ocuk-gaming-eagle-i9-2024-gaming-pc-300x300.jpg)
OcUK Gaming Eagle Custom PC
- Configurable gaming PC – adjust the base spec to suit your needs!
- Intel Core i9-14900KF CPU
- AMD Radeon RX 7900 XTX GPU
- Flexible storage – up to three SSD
- Up to 64GB DDR4 RAM
OcUK Gaming Sabre Configurable PC
- Intel Core i7-13700F CPU
- NVIDIA GeForce RTX 4070 GPU
- Flexible SSD storage
![OcUK Gaming Sabre - Intel 12th Gen i5, RTX 4060 Ti Gaming PC](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/ocuk-gaming-sabre-pc-300x300.jpg)
AMD Processors
AMD Ryzen 9000 Series is the current generation of AMD processors. They are built on Zen 5 architecture and utilise the same AM5 socket and platform, with support for DDR5 RAM, PCIe 5.0, and more.
Zen 5 Architecture
While Ryzen 9000 uses the same socket and 5nm process introduced with Ryzen 7000 Series, the Zen 5 architecture provides an uptick in performance so you can get the best from your gaming whilst still being future proofed for upcoming tech. Plus, these processors are optimised to handle AI workloads, so you can push the limits of what AI can achieve!
Precision Boost & Overclocking
AMD Precision Boost 2 technology automatically increases the performance of your CPU when you need it by dynamically increasing your CPU’s clock speed. What’s more, AMD processors can be overclocked with one click! Precision Boost Overdrive allows you to turbo charge your PC automatically with one button, taking the hassle and confusion out of overclocking your CPU.
StoreMI & Master Utility
Take full control of your Ryzen powered PC with full system monitoring, overclocking, and optimisation via the AMD Ryzen Master Utility Software. Additionally, AMD StoreMI allows you to combine the performance of your SSD with the capacity of your HDD to help slash loading times.
![Upgrades You Need for the AMD Ryzen 9000 Series](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/09/Upgrades-for-AMD-Ryzen-9000-150x150.png)
Check out the upgrades you need to get the most out of AMD Ryzen 9000 Series processors!
Which AMD CPU Should I choose?
The AMD Ryzen 5000, 7000, 8000, and 9000 Series CPUs offer outstanding performance for gamers, creators, and professionals alike. Within the line-ups, there are three tiers of CPU: Ryzen 9, Ryzen 7, and Ryzen 5, of which there are multiple variants.
Ryzen 9 CPUs are AMD’s top consumer processors and offer truly exceptional performance for enthusiast gaming, professional work, and creators. Ryzen 9 CPUs, such as the 7950X, are equipped with up to 16 cores (32 threads), up to 5.70Hz boost clock speed, and support for DDR5 RAM.
Ryzen 7 CPUs offer a great choice for gamers looking to play the latest AAA games at high refresh rates and 4K resolutions. Featuring up to 8 cores (16 threads), up to 5.40GHz clock boost speed, and support for DDR5 RAM. Processors like the Ryzen 7 7700X is perfect for gamers.
A gaming sweet spot, AMD Ryzen 5 processors offer a great price to performance ratio with 6 cores (12 threads), clock boost speed of up to 5.10GHz, and support for DDR5 RAM.
See what our resident champion overclocker had to say about the AMD Ryzen 9000 Series!
Looking for a Pre-Built AMD PC?
Time to game? Overclockers UK stocks a huge range of AMD-based gaming PCs, including our pre-built Refract Gaming PCs. All pre-built, pre-tested, and ready to ship for next day delivery, Refract Gaming PCs are available in a range of configurations set to meet every budget.
OcUK Gaming Oxygen Custom PC
- Customisable gaming PC – adjust the base spec to suit your needs!
- AMD Ryzen 5 7500F CPU
- Your choice of AMD and NVIDIA GPUs
- Flexible storage – up to three SSDs
- Up to 64GB DDR5 RAM
![OcUK Gaming Oxygen - AMD Ryzen 5 7500F, GeForce RTX 4060Ti Gaming PC APNX C1 Case](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/ocuk-gaming-oxygen-apnx-case-pc-300x300.jpg)
![Refract Gaming Celeste 2023](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/05/2023-refract-celeste-hero-300x300.jpg)
Refract Gaming Celeste – 1080p/1440p Pre-Built Gaming PC
- Pre-built gaming PC – fully tested and ready to ship!
- AMD Ryzen 7 7700X CPU
- NVIDIA RTX 4070 GPU
- SSD storage
- 32GB DDR5 RAM
![Refract GFX square](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/Refract-Updated-Eshot-300x300.jpg)
There’s a Refract Gaming PC for every budget. Not sure which one is for you? Answer some simple questions about what games you play and at what resolution, and we’ll match you with your perfect gaming companion. Or read up on each individual model in our dedicated blog.
Discover More About Your Processor!
If you’d like to brush up on your CPU knowledge, check out these blogs on the Overclockers UK!
Are you Team Red or Team Blue?
Thanks to huge generational achievements over the last few years, both AMD and Intel offer CPUs that are pretty much on par with each other. This is especially true when it comes to gaming. So, are you an Intel or AMD gamer? Let us know in the comments.
PC specs are subject to change.
