Is the NVIDIA GeForce RTX 3060 GPU still good for gaming?
To answer this question, we’ll be taking a closer look at this GPU, showcasing the level of expected performance, and the games you can play.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/Is-the-3060-Good-for-Gaming-1024x1024.jpg)
Why is the NVIDIA GeForce RTX 3060 Good for Gaming?
Released in 2020, the NVIDIA RTX 3060 is still a high-quality GPU for mid-tier gaming and budding content creators. Thanks to Ampere architecture, this graphics card delivers fast speeds and smooth frame rates. What’s more, with both RT and Tensor cores, enjoy realistic lighting and shadows as you explore your favourite gaming worlds. All of which you can achieve at a more accessible price point, perfect for those shopping for a GPU on a budget!
![Gigabyte GeForce RTX 3060 WindForce OC LHR 12GB GDDR6 PCI-Express Graphics Card](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/11/gigabyte-geforce-rtx-3060-windforce-gpu-300x300.jpg)
Key Features of the NVIDIA GeForce RTX 3060 |
Ampere architecture |
3584 CUDA cores |
2nd gen RT cores |
3rd gen Tensor cores |
1.78GHz boosted clock speeds |
12GB GDDR6 video memory |
170W TDP |
Similar to all of NVIDIA’s graphics cards, the GeForce RTX 3060 12GB comes equipped with a suite of intelligent features designed to enhance both performance and visuals. This includes NVIDIA Reflex, Ansel, and GeForce Experience.
In our ‘NVIDIA Inside Look’ series, we take a look at all of this dedicated software and how can utilise them in both your gameplay and creative workflows.
What Level of Performance Can I Achieve with an RTX 3060?
Armed with an NVIDIA GeForce RTX 3060 12GB GPU, you can enjoy immersive gaming at up to 1080p/1440p resolutions. It is perfect for every type of gamer, capable of running casual entry-level titles such as Fortnite or Stardew Valley to AAA games including Elden Ring and Cyberpunk 2077.
Regardless of your choice of game, the GeForce RTX 3060 will render the world in smooth realistic light on max settings at 1440p. No more pesky display stutter or lag breaking up your immersion!
What other graphics cards are perfect for 1080p and 1440p gaming? Check out the full list on our blog post.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/FOR-1080P1440P-gaming-GPUS-Best-300x300.jpg)
What Games Can I Play on the NVIDIA RTX 3060?
The NVIDIA GeForce RTX 3060 12GB is capable of running a huge range of the latest AAA titles. Some of our favourites include:
- Grand Theft Auto V
- Elden Ring
- Cyberpunk 2077
- Minecraft
Torn Between an RTX 30 or 40 Series?
Can’t decide whether you should upgrade to an NVIDIA GeForce RTX 30 or 40 Series graphics card? Check out our dedicated guide in which we weigh up the pros and cons of both series to help you decide.
![NVIDIA RTX 30 Series vs 40 Series](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/nvidia-30-vs-40-series-300x300.png)
Looking to Upgrade?
Have you decided the NVIDIA RTX 3060 is for you? At Overclockers UK, you can find plenty of RTX 3060 GPUs available* as stand-alone graphics cards.
MSI GeForce RTX 3060 Ventus 2X OC 12GB GDDR6 Graphics Card
- NVIDIA RTX 30 Series
- Ampere architecture
- 3584 CUDA cores
- 12GB GDDR6 video memory
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/MSI-RTX3060-300x262.jpg)
![Asus GeForce RTX 3060 Dual V2 OC LHR 12GB GDDR6 PCI-Express Graphics Card](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/09/asus-3060-dual-v2-gpu-300x300.jpg)
ASUS GeForce RTX 3060 Dual V2 OC 12GB GDDR6 Graphics Card
- 3584 CUDA cores
*Please note, there is limited availability on some models in the NVIDIA RTX 30 Series.
Do You Utilise A NVIDIA RTX 3060?
Does your PC have an RTX 3060? How has it improved your gaming experience? Let us know in the comments.
Asus Nvidia Geforce dual 3060 12 gb graphics card makes excellent choice for game lovers with appropriate CPU and RAM
