Are you looking to upgrade your GPU but don’t know which card or series is right for you?
Our two-part ‘Is It Good for Gaming’ series is here to take you through the AMD Radeon RX 7000 and NVIDIA RTX 40 Series. We’ll be showcasing everything you need to know about these graphics cards, highlighting key features and explaining why you want them for gaming.
This blog post is all about the NVIDIA RTX 40 Series.
The NVIDIA RTX 40 Series
Utilising powerful Ada Lovelace architecture, the RTX 40 Series has been designed for gaming, streaming, and content creation. The custom-made TSMC 4n process and 76 billion transistors deliver outstanding performance, ultra-fast speeds, and premium response times in all your favourite AAA games or demanding creative workloads.
Our ultimate guide to the RTX 40 Series goes into more detail about this GPU series, including all the hardware you need to upgrade.
The GPUs:
Below are all the GPUs currently in the RTX 40 Series, including the Super and Ti variants.
- RTX 4090
- RTX 4080 Super
- RTX 4080
- RTX 4070 Ti Super
- RTX 4070 Ti
- RTX 4070 Super
- RTX 4070
- RTX 4060 Ti
- RTX 4060
RTX 4090 | RTX 4080 Super | RTX 4080 | RTX 4070 Ti Super | RTX 4070 Ti | RTX 4070 Super | RTX 4070 | RTX 4060 Ti | RTX 4060 | |
Architecture | Ada Lovelace | Ada Lovelace | Ada Lovelace | Ada Lovelace | Ada Lovelace | Ada Lovelace | Ada Lovelace | Ada Lovelace | Ada Lovelace |
CUDA Cores | 16385 | 10240 | 9728 | 8448 | 7680 | 7168 | 5888 | 4352 | 3072 |
Base Clock | 2.23GHz | 2.21GHz | 2.51GHz | 2.34GHz | 2.31GHz | 1.98GHz | 1.92GHz | 2.31GHz | 1.83GHz |
Boost Clock | 2.52GHz | 2.55GHz | 2.21GHz | 2.61GHz | 2.61GHz | 2.48GHz | 2.48GHz | 2.54GHz | 2.46GHz |
VRAM | 24GB | 16GB | 12GB | 16GB | 12GB | 12GB | 12GB | 8GB | 8GB |
Memory Bus | 384-bit | 256-bit | 256-bit | 256-bit | 192-bit | 192-bit | 192-bit | 128-bit | 128-bit |
TDP | 450W | 320W | 320W | 285W | 285W | 220W | 200W | 160W | 115W |
Why You Want the RTX 40 Series for Gaming
Here are our top five reasons why you want an NVIDIA RTX 40 GPU for gaming.
Dedicated Ray Tracing Cores
Dedicated RT cores render your gaming worlds like never before thanks to support for Real-Time Ray Tracing. Ray Tracing simulates how natural light behaves to facilitate realistic shadows and lighting, giving your games an extra boost to fully immerse you.
NVIDIA DLSS
DLSS, or Deep Learning Super Sampling, is NVIDIA’s AI upscaler which intelligently boosts your frame rates, enhances image quality, and ensures ultra-fast response times. The latest gen of DLSS, 3.5, now includes a built-in Ray Reconstructor to reduce excess image noise to heighten your in-game immersion.
If you want to see how DLSS compares to other display technologies, check out our upscaling showdown for more!
Built-in NVIDIA Encoder (NVENC)
NVIDIA NVENC is a built-in encoder designed to encode your video, reduce excess strain on your processor, and boost your stream. There are multiple generations of codec, with the latest gen AV1, boasting less disk space and bandwidth to deliver high-quality recording.
Our NVIDIA Inside Look series takes a closer look at powerful integrated tech featured on all NVIDIA GPUs, including NVIDIA NVENC.
NVIDIA Broadcast
NVIDIA Broadcast is a dedicated plug-in which works alongside a range of live streaming services. It harnesses the Tensor cores on your GPU to streamline any AI workloads and level up your stream. This includes noise and echo removal, virtual backgrounds, and the uncanny eye contact feature.
We covered NVIDIA Broadcast and all the different features you can find in our NVIDIA Inside Look series. Check it out below.
G-Sync
NVIDIA G-Sync is their powerful display technology designed to eliminate screen tearing and display stutter to give you that competitive in-game edge. G-Sync requires a compatible monitor and graphics cards to work correctly.
Which GPU Should You Buy For…
Casual/Entry-Level
For entry-level gaming, we recommend the RTX 4060 Ti. Powered by 4352 CUDA cores and boosted clock speeds of 2.54GHz, this GPU will deliver high-res visuals and fast response times. Everything you need to defeat your in-game enemies with ease.
ASUS GeForce RTX 4060 Ti Dual OC 8GB GDDR6 Graphics Card
- 4352 CUDA cores
- 2595MHz boosted clock speeds
- 8GB GDDR6 video memory
- Two integrated fans
Mid-Range
Alternatively, for mid-range gaming, the NVIDIA RTX 4070 Super Ti is the perfect choice. With 8448 CUDA cores, 2.61GHz clock speeds, and 16GB VRAM, this GPU will power your gaming worlds with stunning realistic visuals and smooth gameplay.
MSI GeForce RTX 4070 Ti Super Gaming X Slim 16GB GDDR6X Graphics Card
- 8448 CUDA cores
- 2.61GHz boosted clock speeds
- 16GB GGDR6X
- Slim all-white design
- Three integrated fans
Enthusiast-Grade
Lastly, for enthusiasts, we recommend the RTX 4090. This flagship graphics card harnesses 16384 CUDA cores to render your favourite games at up to 2.52GHz. All whilst 24GB GDDR6X video memory ensures minimal latency or lag for an optimised performance every time.
Gigabyte AORUS GeForce RTX 4090 Master 24GB GDDR6X Graphics Card
- 16384 CUDA cores
- 2550MHz boosted clock speed
- 24GB GDDR6X video memory
Don’t Want to Build Your Own PC?
Don’t want to build your very own gaming PC? It’s no biggie, as at Overclockers UK you can find plenty of pre-built and configurable PCs that utilise an RTX 40 Series GPU. We’ve searched high and low throughout our website and put together our top PC recs below.
Refract Gaming Jade Pre-Built PC
- Pre-built gaming PC
- Designed for mid-tier gaming and budding content creators
- AMD Ryzen 7 7700 CPU and NVIDIA RTX 4060 Ti
- Up to 32GB DDR5 RAM
- 1TB M.2 SSD
OcUK Gaming Katana Configurable PC
- Configurable gaming PC
- Adjustable base hardware specification
- As standard includes an Intel i7 14700KF CPU and NVIDIA RTX 4070 Ti Super
- 32GB DDR5 RAM
- Optional secondary SSD
Infin8 Venomous High-End Watercooled PC
- High-end gaming PC
- Custom water-cooling loop
- Intel Core i7 14700K CPU and NVIDIA RTX 4080 Super
- 32GB DDR5 RAM
OcUK Gaming Radiance Drift Configurable PC
- Customisable hardware specification
- As standard includes an Intel i9 14900KF CPU and NVIDIA RTX 4090
- 32GB DDR4 RAM
- Optional secondary storage drives to choose form
Have You Upgraded to an NVIDIA RTX 40 Series?
Have you recently upgraded to an RTX 40 Series? What are your thoughts on this graphics card? Let us know in the comments.
*Prices correct at time of writing and PC specs are subject to change.
