![LianLiUniFanAL120-Main](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/07/LianLiUniFanAL120-Main-1024x576.jpg)
Complementing any gaming PC with aesthetical style, daisy-chained ARGB fans have revolutionised cooling – bringing functionality and pizazz to any set-up. The Lian Li Uni Fan AL120 is the latest example. These 120mm PWM ARGB fans can be easily connected with multiple units using a slide-in interlocking mechanism. This latest Lian Li Uni Fan will grant you the best performance from the range yet. Adding to its improved airflow, stability, and durability is a vast variety of exciting lighting combinations. Masterful control is at your disposal, courtesy of Lian Li’s L-Connect 2 software. Whether you wish to connect just a single unit, or control up to four connected fans with jaw-dropping colour combinations, the Lian Li AL120 leaves the choice up to you.
![Lian Li Uni Fan AL120](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/07/al120_13-300x300.jpg)
Easy-to-Use Daisy-Chained Fans
Revolutionising installation, the Lian Li Uni Fan AL120’s slide-in interlocking daisy-chain system is simple and seamless. As soon as your required number of fans are all connected, signals will be seamlessly passed through pin-to-pin contact. So, you’ll quickly be able to dazzle your PC with vividly rich colours.
To control colour combinations along with fan speeds, you’ll need to use the exclusive Lian Li UNI HUB controller. This controller will enable you simultaneous control of up to 16 fans (4 fans per group), using multiple options for connectivity. An important detail to note, however, is that the Lian Li Uni Fan AL120 single pack does not include a UNI HUB controller. This controller is only available in the Lian Li Uni Fan AL120 triple pack. The single pack serves as an extension.
Additionally, these high-quality fans have been manufactured with reflective, brushed aluminium on the side. Joining the rear metallic ARGB medallion at the centre is an X-style fan support to smoothly tuck your cables away. So, your PC will be kept nice and tidy
![Lian Li Uni Fan AL120](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/al120_09.jpg)
Limitless Lighting Combinations
The Lian Li Uni Fan AL120 comes with a grand variety of pre-set lighting modes to make your gaming PC shine. Included in these 50+ presets are modes like “tornado”, “rainbow”, “spinning teacups”, and the visually soothing “tai chi”. What’s more, the Lian Li AL120’s design takes this a step further. By manufacturing ARGB LEDs on the inner fan, along with the four corner edges of the frame. As a result, you’ll be able to set individual colour arrangements for thousands of combinations. These will merge to create awe-inspiring displays that are truly unique and your own.
All of your Lian Li AL120 Uni Fans can be controlled with precision via the L-Connect 2 software. You’ll be given full authority over your gaming PC’s lighting and cooling using an intuitive UI. Able to connect with up to four controllers, the Lian Li L-Connnect 2 can potentially pair with a maximum of 64 fans. All from one interface!
If you’re operating multiple systems, needing to adjust the lighting on one, or adjust the fan speed between 800 and 1900RPM on the other, you’ll have no problem whatsoever.
![Lian Li Uni Fan AL120](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/al120_19.jpg)
Amazing Performance
Incredible cooling control and lighting capabilities wouldn’t be much without the high-quality hardware to back it up. Optimised to provide lower noise levels and improved airflow, the Lian Li Uni Fan AL120 offers the best performance to ever come from the series. The stator, the small coil inside the fan’s engine, utilises a rotating magnetic field to enhance momentum. Meanwhile, the rubber pads along with the fan frames, work to reduce the resulting vibrations, keeping noise levels nice and quiet.
Lian Li has built every Uni Fan to last, and the AL120 is no different. This is by virtue of the fluid dynamic bearing (FBD), dramatically lowering levels of internal friction. Finally, bolstered by a magnetic frame, the Lian Li Uni Fan AL120 comes with larger impellers, each delivering more efficient cooling than you could ever have hoped for.
![Lian Li Uni Fan AL120](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/al120_16.jpg)
Available in black or white, the Lian Li Uni Fan AL120 is ready to revolutionise your gaming PC’s cooling and ARGB displays. Whether you’re arming your personal battle station, or are refining your management of multiple systems, this fan kit with L-Connect 2 software will make you the master of your domain.
- Daisy-chain design – up to four fans
- Limitless ARGB LED lighting combinations
- Precise control via L-Connect 2 software
- Incredible airflow, efficiency, and stability
![Lian Li Uni Fan AL120](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/03/al120_03.jpg)
