With the Jonsbo HX Series CPU coolers, you’ll be able to choose a stylish and powerful air cooler for your processor. From a low-profile downdraft cooler perfect to fit in a mini-ITX build, to a twin tower beast that can handle even the most powerful of processors. This line of coolers brings stylish aesthetics, support for a wide variety of CPUs, and, most importantly of all, truly impressive cooling performance.
![Jonsbo HX Series CPU Coolers](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/2202-jonsbo-hx-coolers-Category-1024x222.jpg.webp)
What Coolers are Available
![Jonsbo HX6200 CPU Cooler installed on motherboard](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/JonsboHX6200installed-300x300.jpg)
Jonsbo HX6200
The HX6200 is a powerful low-profile downdraft cooler. The cooler stands at just 63mm tall, perfect for a small form factor build. This cooler comes with a stylish all-white finish and with an aRGB fan, you’ll be able to complete the aesthetic of your PC.
Jonsbo HX6210
The HX6210 is a mighty little tower punching above its weight. Standing at just 125mm tall and utilising a 90mm fan that can boast a fan pressure of 2.73mmH2O, this small package will be able to keep your powerful CPU running at peak performance.
![Exploded view of Jonsbo HX6210 cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/jonsbo_6210_exploded_view-300x300.jpg)
![Jonsbo HX6250 cooler mounted on a motherboard](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/jonsbo_6250_ram_offset-300x300.jpg)
Jonsbo HX6250
With its offset design, the HX6250 can easily be installed alongside high-profile RAM modules and still perform exceptionally well. With a TDP of 250W, no matter how hot your CPU runs this cooler will be able to keep it from throttling.
Jonsbo HX7280
Featuring a dual tower design, the HX7280 can boast exceptional thermal performance. Coming with a trio of fans to choose from, you’ll have exceptional airflow through the heat sinks whatever your setup.
![Jonsbo HX7280 exploded view](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/jonsbo_7280_exploded_view-300x300.jpg)
CPU Coolers for High Powered Processors
![Jonsbo HX6250 CPU Cooler with cover removed](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/Jonsbo6250cover-300x300.jpg)
The greatest achievement of these CPU coolers from Jonsbo is their amazing thermal performance. For example, even the low-profile option the HX6200 boasts a TDP of 200W. This puts it in the realm performance-wise of standard tower coolers. The rest of the line only gets better from there, with the HX7280 dual-tower beast reaching a mind-boggling TDP of 280W. This thermal performance allows it to even handle the powerhouse 12th Generation of Intel CPUs which have been known to get a bit toasty when pushed to their limit.
Now you’d expect this performance to come with some sort of drawback, for example utilising unsightly hardware. But you’d be wrong the Jonsbo series of coolers all feature sublime designs that anyone would be proud to host within their PC. From the striking white finish of the HX6200 that is emphasised by its aRGB fan, to the all-black finish of the HX6250 which also features a magnetic top cover that can be used to hide the heat pipes.
Faultless Fans
With the HX series of coolers, Jonsbo has included a variety of different fans, but for all their differences these fans share the same uncompromising performance. These fans are able to channel a truly staggering amount of air. The 92mm fan that comes with the HX6210 when pushed to its maximum output is able to achieve a CFM of 45.52.
![Jonsbo fan exploded view](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/01/jonsbo_fan_breakdown-300x300.jpg)
You’d expect these fans to be loud, but Jonsbo has worked to make sure they’re not. The fans have been dynamically balanced twice to reduce the vibrations they create. This alongside a build that includes shock absorption feet and fluid dynamic bearings, makes these fans whisper quiet. If pushed to its maximum output of 1800RPM, the 140mm fan will produce just 38dB(A) that’s the same as you’d find in a library.
Pre-Order your CPU Cooler Today
If you’re after spectacular cooling for your powerful CPU, then pre-order one of these amazing choices at Overclockers UK.
Jonsbo HX6200
- Low Profile Cooler
- 63 x 120 x 120mm (H x W x L)
- 200W TDP
- Supports a range of Intel and AMD CPUs
- aRGB Fan
![Jonsbo HX6200 CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/JonsboHX6200-300x300.jpg)
![Jonsbo HX6210 CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/JonsboHX6210-300x300.jpg)
Jonsbo HX6210
- Single Tower Cooler
- 125 x 92 x 92mm (H x W x L)
- 210W TDP
- Off set design to avoid RAM
Jonsbo HX6250
- Single Tower Design
- 162 x 121 x 144mm (H x W x L)
- 250W TDP
- Six 6mm Heat Pipes
![Jonsbo HX6250 CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/JonsboHX6250-300x300.jpg)
![Jonsbo HX7280 CPU Cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/02/JonsboHX7280-300x300.jpg)
Jonsbo HX7280
- Dual Tower Cooler
- 160 x 140 x 155mm (H x W x L)
- 280W TDP
- Choice of fans to suit your build
Great article, these fans look really nice!
