Over the last year Jonsbo have made a strong entry into the UK market. With a variety of PC case and accessories on offer, their hardware is characterised by solid build quality but is also available at a great price point. They now add a new series of ATX PC cases to their already ample lineup of products: the TR03.
Astonishingly Angular
What sets the TR03 apart from the competition is undoubtedly its unique, highly modern, and angular design. Its uncommon shape is particularly well highlighted with RGB illumination.
The TR03 series is subdivided into the TR03-A and TR03-G cases. Both models have the same overall design and dimensions but the G version features tempered glass on both the side and front panels with the A version having only tempered glass on the side. Either way you can rest assured you are getting a high quality and impressive case.
Features of the TR03 Series
These stylish cases have all the features you would expect from an outstanding ATX case. For instance:
- Capacity for three 2.5″ SSDs and three 3.5″ HDD or a total of five 2.5″ SSD
- A variety of cooling options including:
– Front: 3 x 120mm (optional)
– Bottom: 2 x 120mm (optional)
– Rear: 1 x 120mm (optional)
– Middle: 2 x 120mm (optional)
– Top: 1 x 120 mm
– Front bottom: 1 x 120mm
Overall then the TR03 series are a great cost effective way to have a true ‘showcase’.
