JONSPLUS, an offshoot of the up and coming manufacturer JONSBO, has just released an innovative case for the design conscious PC enthusiast. The BO 100 is a stylish mini-ITX PC case with a unique look and compact form factor.
JONSPLUS has quickly established itself as a high-end brand, catering to the premium PC market. They have applied this philosophy to the BO 100. It boasts not only an eye-catching, sandblasted aluminium exterior, but a host of special design features.
Take my hand
Not since the venerable Nintendo GameCube has a handle taken centre-stage on gaming hardware. Having said that, JONSPLUS are actually imitating more the look of high-end hi-fi components. Such as what you’d find on the likes of a Bang & Olufsen audio set.
A distinctly classy look is achieved through the use of high-quality materials in the BO 100’s construction.
This is further complemented by a tempered glass front panel. The panel is almost completely tinted black, but for a window towards the top to view hardware through. Its design differentiates the BO 100 from its competition, and creates a look that is particularly effective when paired with RGB components.
Airflow is also well-supported with vents at the base, sides and rear of the case. As well as that, there is room in the front for a 120mm fan or radiator. Additionally, there is sufficient clearance for a 158.5mm CPU cooler and dual-slot GPU up to 207mm long.
A handy case
Installing hardware is made easy thanks to a sliding mechanism JONSPLUS have developed. Much like opening a drawer, users can simply slide the inner chamber out from the main chassis. Another faux-leather strap on the back makes it easy sliding the inner section out.
All in all, the JONSPLUS BO 100 is the perfect case for anyone looking for an extremely stylish yet relatively compact PC case.
JONSPLUS BO 100 – Silver
- Compact Mini-ITX case
- Sandblasted aluminium exterior
- Faux leather carrying handle
- Tempered Glass front panel
JONSPLUS BO 100 – Black
