![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/i100Pro-CatBan-1024x222.jpg)
Though a relatively new comer to Western markets, Jonsbo has quickly established itself as a brand offering great value and high quality PC cases.
With the i100 Pro series, sold under their new Jonsplus brand, they have upped their game and now offer premium mini-ITX cases made from a high-quality aluminium-magnesium alloy.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/jonsplus_white_tg_basic-1024x747.png)
i-nnovative
The i100 Pros comes in four variants: with or without a temper glass side panel and in either black or silver. The emphasis here is both on build quality and interior modularity. Indeed as far as mini-ITX cases go, the i100 is extremely flexible and can easily accommodate powerful gaming hardware.
This flexibility is due to a clever mechanism that allows user to adjust the motherboard tray position and arrange components within three different configurations. This means users can create the ideal PC for their specific needs.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/02/jonsplus_black_details-1024x747.jpeg)
See the table below for details on what is possible in each configuration:
Configuration | GPU |
Dual chamber design with vertical GPU and with AIO cooler | Graphics cards: 345 – 373 x 160 x 62 mm (L x W x H) CPU cooler: max. 77 mm height Radiator: 360/280/240/120 (max. 55 mm thickness (radiator + fan)) Power supply: ATX / SFX with max. 175/150 mm length (with / without bottom fan) Fan: 6x 120 / 4x 140 mm ——– |
Single chamber design with horizontal GPU and CPU air cooler | Graphics cards: 345 – 373 x 160 x 62 mm (L x W x H) CPU cooler: max. 166 mm height Power supply: ATX / SFX with max. 140 mm length Fan: 3x 120 / 2x 140 mm ——– |
Single-chamber design with horizontal GPU and AIO cooler | Graphics cards: 345 – 373 x 160 x 62 mm (L x W x H) Radiator: 360/280/240/120 (max. 55 mm thickness (radiator + fan)) Power supply: SFX with a maximum length of 115 mm Fans: 3x 120 / 2x 140 mm ——– |
If you want a compact and elegant mini-ITX case, consider picking up a Jonsplus i100 Pro Mini-ITX.
