Keep your NVIDIA RTX 40 Series GPU cool with the Phanteks Glacier G40 water blocks, tailor-made for next-gen gaming.
![Phanteks Glacier G40 Water block](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Phanteks-Glacier-G4090-MSI-Gigabyte-update.png.webp)
Phanteks has expanded their much-loved Glacier water block series. Introducing the Phanteks Glacier G40 Series. These water blocks are designed to be used with RTX 40 Series graphics cards from MSI, ASUS, and Gigabyte. With the RTX 4090 being a veritable beast, the Glacier G40 water blocks are primed for high-performance cooling while sporting impeccable style. Everything you need in a water block!
There are nine water blocks joining the line-up. Not only do we have a selection of blocks for three different brands, but they are also available in three different colours. Pair with an MSI, ASUS, or Gigabyte GPU, and select from black, white, or chrome. All with beautiful DRGB lighting too!
Glacier G40 ASUS
Satin Black
![Phanteks Glacier G40 ASUS Water Block Satin Black](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/Glacier_G40_Asus_01_Black.jpg.webp)
- ASUS ROG Strix GeForce RTX 4090 24GB
- ASUS ROG Strix GeForce RTX 4090 OC Edition 24GB
- ASUS TUF-RTX4090-O24G-GAMING
- ASUS TUF-RTX4090-24G-GAMING
Glacier G40 MSI
Matte White
![Phanteks Glacier G40 MSI
Matte White Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glacier_G40_MSi_01_White.jpg.webp)
- MSI GeForce RTX 4090 SUPRIM X 24G
- MSI GeForce RTX 4090 SUPRIM 24G
- MSI GeForce RTX 4090 GAMING X TRIO 24G
Glacier G40 Gigabyte Chrome
![Phanteks Glacier G40 Gigabyte
Chrome Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glacier_G40_Gigabyte_01_Chrome.jpg.webp)
- GIGABYTE AORUS GeForce RTX 4090 MASTER 24G
- GIGABYTE GeForce RTX 4090 GAMING OC 24G
Premium Materials
The backbone of these water blocks is the premium materials that have been utilised. Specially selected for their durability, conductivity, and and a touch of luxury. A water block is made up of a coldplate, jetplate, and cover – plus these models include a separate, dedicated backplate for extra strength and support. Here is a breakdown of each of these components and their materials:
- Coldplate. The coldplate is manufactured from 100% copper, a highly conductive material ideal in any thermal solution.
- Jetplate. The jetplate holds the liquid coolant that draws heat away from the graphics card. The chosen material is clear cast acrylic, perfect for showing off coloured coolant and the DRGB lighting.
- Backplate. The dedicated backplate is aluminium, lending strength and stability to the mounting process. This attaches to the rear PCI bracket and includes a 0.25mm Mylar layer.
- Covers. The covers are also aluminium, coloured either in satin black, chrome, or matte white. Like the backplate, this also helps to provide structural integrity to the water block.
- O-rings. To keep the system water-tight, these water blocks utilise Viton O-Rings. These are primarily used in automotive and aerospace industries, because of their incredible durability and reliability. You won’t be springing a leak with these!
![Phanteks Glacier G40 ASUS Water Block Chrome](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/Glacier_G40_Asus_03_Chrome.jpg.webp)
![Phanteks Glacier G40 MSI Water Block Black](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glacier_G40_MSi_02_Black.jpg.webp)
High-Performance Cooling
With an excellent foundation of premium materials, the Phanteks Glacier G40 Water Block is primed for high-performance cooling. Firstly, the coldplate fully covers the graphics card – maximising contact. Most importantly, it directly cools the memory and the power delivery components on the PCB. Next, the jetplate rests directly over the GPU die, ensuring optimal heat transfer. What’s more, the backplate may be included for structural integrity, but the aluminium also serves as a heat sink, too! Tasty stuff.
In addition to all this, there has been a quality-of-life improvement made on the Phanteks Glacier G40 Series. The fitting locations have been moved, thus making tube routing much easier. Especially helpful in small form factor builds. As such, these water blocks can be seamlessly integrated into your gaming PC with ease. Enjoy the enhanced cooling whilst you game with phenomenal graphical prowess!
![Air cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/pexels-2225617-square-150x150.jpg.webp)
Want to learn more about the ins and outs of water cooling? Check out our blog, where we compare air and water cooling to learn which is best for your gaming PC!
DRGB Lighting
The final touch on the Phanteks Glacier G40 Series is the DRGB lighting. Phanteks products are known for their beautiful illumination, and these water blocks are no exception. Each model features 15 vivid LED chips that can be digitally addressed and synchronised with other Phanteks DRGB devices, via compatible software.
Give your RTX 4000 Series graphics card the showcase lighting it deserves!
![Phanteks Glacier G40 MSI Water Block Chrome](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glacier_G40_MSi_07_Chrome.jpg.webp)
![Phanteks Glacier G40 ASUS Water Block Matte White](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/Glacier_G40_Asus_02_White.jpg.webp)
Cool Your RTX 40 Series Now
If you’ve got your hands on an NVIDIA RTX 40 Series GPU, then pair it with phenomenal cooling. The Phanteks Glacier G40 Series are all available now to pre-order at Overclockers UK.
- Water block designed for ASUS RTX 40 Series GPUs
- Premium materials
- Viton O-Rings
- New fittings location for improved routing
- 15 DRGB LED chips
![Phanteks Glacier G40 ASUS Water Block Chrome](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/Glacier_G40_Asus_01_Chrome.jpg.webp)
![Phanteks Glacier G40 Gigabyte Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glacier_G40_Gigabyte_01_Black.jpg.webp)
- Water block designed for Gigabyte RTX 40 Series GPUs
- Cast acrylic and 100% copper
- Highly durable Viton O-Rings
- Include aluminium backplate
- 15 DRGB LED chips
- Water block designed for MSI RTX 40 Series GPUs
- Aluminium backplate with Mylar layer
- Durable and conductive materials
- Quality-of-life design improvements
- 15 DRGB LED chips
![Phanteks Glacier G40 MSI Water Block](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/11/Glacier_G40_MSi_01_White-1.jpg.webp)
