Kolink has an excellent range of beautiful and innovative PC cases. The collection has just got bigger, hencher, more shredded, and suitable for oversized rabbits. The Kolink Big Chungus range has two new cases in its line-up: Hench and Shredded. Breaking the mould, these ATX chassis sport innovative designs, integrated cooling, and full support for all your gaming hardware. Feast your eyes on these big bois.
Get Shredded
The Kolink Big Chungus Shredded ATX Case is a marvel to behold. Its industrial, diagonal design paired with futuristic panelling make this a wonderfully unique case. The Kolink Umbra aRGB fans add a splash of colour whilst the elevated tempered glass panels provide the perfect window into your PC. Inside, there is support for up to an ATX motherboard, 310mm long GPU, and 165mm tall CPU cooler. Plus, there are drive bays for 1 x 3.5” HDD and 2 x 2.5” SSDs, providing a flexible storage solution for your gaming PC.
Considering the Big Chungus Shredded’s unique design, a custom water-cooling loop is the best way to keep this beast cool. There is support for a 360mm radiator on the front and a 240mm upon the top. This creates the potential for even a dual-radiator loop for immense thermal performance.
Feeling Hench
Internally, the Kolink Big Chungus Hench ATX Case sports many of the same features as its Shredded counterpart. There’s support for up to an ATX motherboard, the back panel features seven expansion slots, and the vented PSU shroud can host an ATX power supply. Plus, this case can also accommodate up to a 310mm long GPU and 165mm tall CPU cooler. Your high-end gaming hardware is going to look amazing within this chassis.
A stark difference, however, is the included aRGB panel on the side of the Big Chungus Hench. Featuring the Kolink emblem and futuristic design, this is the first Kolink case to feature an aRGB panel on the side rather than the front. This stunning addition looks incredible with the Kolink Umbra fans and is sure to dazzle.
Kolink Umbra aRGB Fans
With a combination of vented panels, featuring the iconic Kolink hexagonal cut-outs, and the elevated tempered glass panels, these cases have exceptional airflow. The Umbra fans further enhance this, thanks to their curved fan blades and speeds up to 1500RPM. Utilising Daisy Chain PWM connectors, you are in full control of how fast these fans need to spin. When operating on lighter loads, you can set them to slower speeds and enjoy near-silent operation.
Each fan sports two rings of vibrant aRGB LEDs, with 12 on the larger and 9 on the smaller circle. This creates a dazzling effect that you can configure either via a compatible aRGB motherboard or the included Kolink Core Controller.
Available Now!
If you’ve found yourself thinking “Man, I wish I had this case!” then rejoice, both of them are now available for pre-order at Overclockers UK. Drop a comment below if you’re going Hench or Shredded!
- Includes Kolink Umbra PWM fans
- Up to ATX motherboard
- Elevated tempered glass panel
- Ventilated panels and PSU shroud
- Industrial diagonal design with iconic panelling
- aRGB side panel and Kolink Umbra fans
- Includes Kolink Core Controller
- Up to 310mm long GPU
- Primed for AiO cooler
- Unique aesthetic
