Kolink does not slow down when it comes to releasing beautiful RGB cases for the budget-conscious PC enthusiast. For the third week in a row, we bring you several new cases joining the Kolink line-up. There is the fantastic dual-chambered, Unity Code X or the flashy, infinity mirror Void rift. Both cases feature fan favourite designs that are sure to stand out in any PC setup. If you just can’t wait to get your hands on one, buy now at Overclockers UK. Alternatively, keep reading to learn more about these incredible cases.
Kolink Unity Code X Mid-Tower case:
The Kolink Unity Code X is a fantastic chassis with a familiar dual-chamber design. This unique shape has become a firm favourite amongst PC enthusiasts. With the code X, Kolink has managed to recreate a more affordable version that still comes with many of the high-end features PC builders expect.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/GEKL_104_07.jpg)
The spacious front chamber is capable of supporting a wide range of air or water cooling hardware. This includes up to 10 fans! This is where Code X gets its Roman Numeral inspired name. Meanwhile, the generous rear chamber has plenty of space for routing unsightly cables. This makes it easy to create a clean and stylish PC build you’ll be proud to show off. The Unity Code X provides performance and a pleasing design at a great price point.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/GEKL_104_04.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/GEKL_104_01.jpg)
The front of Unity code X is adorned with attractive ARGB lighting which can be synchronised with compatible hardware. Perfect if you’re installing an Asus Aura or MSI Mystic light motherboard. To show off all that lighting the dual tempered glass side panels provide an unobstructed view of the interior components.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/GEKL_104_02.jpg)
Top Features:
- Clever dual chamber design hides unsightly hardware and showcases the best components.
- Umbra Void 120mm ARGB fan included for extra airflow.
- ARGB lighting synchronises with compatible hardware.
- Support for up to 10 fans and 3 x 360mm radiators.
- Dual Tempered glass side panels.
- Vertical GPU support bracket included – riser cable sold separately.
Kolink Void Rift ARGB Gaming case:
The Kolink Void Rift definitely takes after its name and the Infinity mirror front panel gives the illusion of a mysterious rift in space. It’s an impressive and eyecatching design and is now available in this much more affordable chassis.
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/GEKL_100_02.jpg)
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/GEKL_100_01.jpg)
The rows of RGB LEDs appear to go on forever and there’s the option to switch between several different colours and preprogrammed effects. If you plan on installing an ARGB compatible motherboard the Void Rift lighting can be synchronised to create a coordinated light show.
Additionally, this vibrant case has plenty of options for installing powerful hardware and attractive RGB fans. It is compatible with ATX, Micro-ATX- or Mini-ITX motherboards, 165mm CPU coolers, and a 355mm graphics card that can be vertically mounted. Finally, there is great support for storage and you can install up to 2 x 3.5” hard drives and 4 x 2.5” solid-state drives in different configurations.
Top Features:
- Preinstalled Umbra Void 120mm ARGB fan.
- ARGB compatible front panel lighting.
- Support for high-end hardware and water cooling.
- Tempered glass side panel gives a clear view of the interior
- Option to vertically mount a GPU – riser cable sold separately
- Front I/O has great USB and Audio connectivity
![](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/08/GEKL_100_07.jpg)
Pick your favourite:
Both of these cases are now available on the Overclockers UK website. Make sure to click “BUY NOW” to check them out. Also, let us know in the comments which one has your favourite design? Do you prefer the sleek and stylish Unity X or the flashy front panel of the Void Rift.
Love great value PC cases?
![kolink-inspire-k5-mid-tower-case-angle-shot-1](https://www.overclockers.co.uk/blog/wp-content/uploads/2021/06/kolink-inspire-k5-mid-tower-case-angle-shot-1.jpeg)
Check out these other great options from Kolink in our dedicated blog posts:
New Kolink Cases Available at Overclockers UK
