The case and accessory specialist Kolink presents the brand new Kolink Citadel, an inexpensive Micro-ATX case that offers numerous features inside its ascetic design. The modern tower has a tinted tempered glass side panel and an elegant aluminium front. Two 240-millimetre radiators can be mounted inside the housing, allowing cooling of powerful hardware in Micro-ATX format.
Perfectly Cooled Powerful Hardware
The modest appearance of the Kolink Citadel Micro-ATX case is deceptive. Powerful gaming hardware can be efficiently cooled inside. The case fits graphics cards up to 35 cm in length and CPU coolers up to 16.2 cm high. Two 240 mm radiator slots are also available for water cooling enthusiasts. Up to five fans can be also mounted instead, two of which are already pre-installed and provide excellent fresh air supply. Thanks to the honeycomb mesh in the lid and the side air inlet in the front, the hardware inside the case is efficiently supplied with cool fresh air. Dust filters keep the interior dust-free.
The Features of the Kolink Citadel at a Glance:
  • Sleek design with an elegant front with the look of aluminium
  • Tinted tempered glass side panel and a mesh lid
  • Space for a 240mm radiator on front and top
  • Room for graphics cards up to 350 mm in length & CPU coolers up to 162 mm in height
  • Two pre-installed 120mm front and rear fans
  • Dust filter on top and the underside
Clean Interior Thanks to Excellent Cable Management
In addition to M.2 SSDs, which are particularly popular with gamers due to their high speed, up to four conventional drives can also be installed in the Kolink Citadel. In the hard drive cage there is space for two 2.5″ or 3.5″ drives, two additional 2.5″ SSDs can be installed on the back of the mainboard tray. Thanks to the power supply cover, the generously sized space behind the mainboard tray and the numerous openings for cable management, the harddrives and the cables needed to build an exceptionally powerful gaming PC disappear from sight. The Kolink Citadel Micro-ATX Tower guarantees a tidy interior that can be admired through the large tempered glass side panel.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
