There are plenty of upgrades to make on our gaming PCs this coming year. Kolink is here to make sure your connections stay up to date with their latest Kolink Core Pro lines.
![Kolink Core Pro 12V-2x6 Cables and Adapters: Ultimate Style and Performance](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/fb-en-kolink-core-pro-extension-kits-core-pro-12v-adapters-1024x1024.png)
These extension cable kits and adapters are designed to work with the new 12V-2×6 standard but are backwards compatible with 12VHPWR. This ensures these products will work cohesively with your set-up, whatever upgrades you choose to make. Plus, there are some exciting colour schemes to match any aesthetic! This could be the finishing touch to your gaming PC.
Kolink Core Pro 12V-2×6
Effectively, there are two product lines available, the Kolink Core Pro 12V-2×6 16-pin 90-Degree Adapters and Kolink Core Pro 12V-2×6 Extension Cable Kits. In each of these, there are multiple models and versions. The adapters come as either Type 1 or Type 2 (don’t worry, I’ll explain that in a moment), and you can choose between black or white editions on both types. The cable kits include the 12V-2×6 adapter, so they are also both available as either Type 1 or Type 2, but you get to choose from seven vibrant colourways!
Oodles of choice!
Kolink Core Pro 12V-2×6 Adapter Type 1
![Kolink Core Pro 12V-2x6 Adapter Type 1](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/01/kolink-core-pro-12v-2x6-adapter-type-1-300x300.jpg)
Kolink Core Pro 12V-2×6 Adapter Type 2
![Kolink Core Pro 12V-2x6 Adapter Type 2](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-adapter-type-2-white-300x300.jpg)
Kolink Core Pro 12V-2×6 Extension Cable Kit Type 1
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 1 Black / Red](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-1-red-300x300.jpg)
Kolink Core Pro 12V-2×6 Extension Cable Kit Type 2
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 2 Pink / Blue / White](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-2-white-blue-pink-300x300.jpg)
With the new 12V-2×6 standard becoming more readily available, it stands to reason that your gaming PC may need an adapter. The Kolink Core Pro 12V-2×6 16-pin 90-Degree Adapter ensures a secure connection to your GPU. The metal casing and conductive materials facilitate efficient heat dissipation, helping to keep operations at peak temperature.
Being angled at 90-degrees means this adapter is great for creating clean cable runs. It eliminates the need for tight bends right where the cable connects, so you can enjoy more consistent and reliable performance.
This adapter has been designed to work with RTX 3090 Ti, 4070 Ti, 4080, 4090, and other 12VHPWR GPUs.
Type 1 vs Type 2
Its type indicates whether the cable will point up or down when installed. Type 1 has the sense pins on the top and generally points down when connected to your GPU. Type 2 is basically the opposite – sense pins on the bottom and generally points up when connected. Which you pick depends entirely on which way you want to run your cables.
![Kolink Core Pro 12V-2x6 Adapter Type 1](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-adapter-type-1-white-300x300.jpg)
![Kolink Core Pro 12V-2x6 Adapter Type 2](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-adapter-type-2-300x300.jpg)
Kolink Core Pro Extension Cable Kit
Now to add a little spice! The Kolink Core Pro 12V-2×6 Extension Cable Kits bring vibrant colours, smooth bends, and support for high-wattage applications to your gaming PC. The internal wiring is 16AWG, to ensure those power-hungry GPUs get all the wattage they need. Plus, the external braiding is manufactured from PET plastic, to keep those bends smooth and provide extra durability, and each cable features three cable combs with a metal-effect finish. Heck, there are even three extra cable combs per cable to really fine-tune your runs.
[h4] What’s in the box?!
This is an eight cable kit, covering a wide selection of connectors to enhance compatibility and suit your needs. Plus, it includes the extra cable combs and 12V-2×6 90-degree angled adapter. You can choose either the Type 1 or Type 2 adapter, whichever orientation will suit your gaming PC best!
Here’s a quick rundown of the full box contents:
- 1 x 12V2x6 90-degree cable, 600mm (600W maximum power delivery)
- 3 x 6+2 Pin PCIe cable, 450mm (300W maximum power delivery)
- 1 x 6-Pin PCIe cable, 450mm (300W maximum power delivery)
- 1 x 20+4 Pin cable, 300mm (350W maximum power delivery)
- 1 x 4+4 Pin cable, 450mm (400W maximum power delivery)
- 1 x 8-Pin cable, 450mm (400W maximum power delivery)
- 3 extra cable combs per cable
- Kolink Core Pro 12V2x6 16-pin 90-degree angled adapter (Type 1 or Type 2)
Seven Colourways
Now the moment we’ve all be waiting for – the colours. I think it’s best if I just let the pictures do the talking for this!
Jet Black
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 2 Black](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-2-black-300x300.jpg)
Brilliant White
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 1 White](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-1-white-300x300.jpg)
Venom Green
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 1 Green](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-1-green-300x300.jpg)
Jet Black + Brilliant White
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 1 Black White](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-1-black-white-300x300.jpg)
Jet Back + Gunmetal Grey
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 2 Black Grey](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-2-black-grey-300x300.jpg)
Jet Black + Racing Red
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 2 Red](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-2-red-300x300.jpg)
Brilliant White + Neon Blue + Pure Pink
![Kolink Core Pro 12V-2x6 Extension Cable Kit Type 1 Pink / Blue / White](https://www.overclockers.co.uk/blog/wp-content/uploads/2024/02/kolink-core-pro-12v-2x6-cable-set-type-1-white-blue-pink-300x300.jpg)
Secure Connectivity
All the Kolink Core Pro products are available to pre-order from Overclockers UK. Drop a comment with the colour scheme that best matches your aesthetic!
