Kolink has come to enjoy quite a reputation for premium build quality at affordable prices. Now they have released the exceptionally stylish Inspire K1 RGB Midi-Tower complete with an attractive acrylic glass side panel and tempered glass front. Behind the front section lie two pre-installed 120 mm RGB-LED fans which are illuminated by means of a honeycomb-shaped frame, taking the whole look of the case to the next level.
The Features of the Kolink Inspire K1 RGB at a Glance
  • Designer case for motherboards up to ATX
  • Acrylic glass side panel and tempered glass front
  • 2x Pre-installed 120 mm RGB-LED fans, 1x 80 mm fan in the back
  • I/O Panel with 2x USB 2.0 / 1x USB 3.0 & HD Audio In/Out
  • Support for a 240 mm format radiator
  • 3x 3.5 and 2x 2.5” slots for storage
  • Supports graphics cards up to 35 cm long & CPU coolers up to 15 cm high
  • Includes fan controller and remote control
Let Yourself Be Inspired!
The RGB-LED fans are connected to an included controller. Users can control the case’s RGB-LED lighting using an infrared remote control. Both front-facing fans are connected using 6-pin connectors to the included controller. The included remote control on the other hand enables users to select from between up to 350 different effects. The neat and tidy interior of the Inspire K1 also leaves plenty of space for high-end gaming hardware. Hardware aside, watercooling and cable management options abound in this case and are just some of its highlights. Its build quality is all the more impressive when you take into account the value for money Kolink is bringing to the table!
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
Inline Feedbacks
View all comments
