The Inspire K4 and Inspire K5 Midi-Towers from Kolink represent an affordable addition to their Inspire range of cases. As expected from the series, these ATX towers are characterised by the striking and unique design of the front along with their digitally addressable RGB-LED lighting, which can be controlled via the I/O panel or via a 3-pin motherboard connection. The neat and tidy interior is ideal for heavy duty gaming hardware: graphics cards can measure up to 350 mm (K4) / 310 mm (K5) and CPU coolers up to 160 mm are compatible. Of course, both cases make use of attractive tinted tempered glass panels.
The Kolink Inspire K4 and K5 ATX Midi-Towers at a Glance:
- Attractively designed front panels complete with RGB-LED lighting
- Compatible with ATX-, Micro-ATX- or Mini-ITX motherboards
- Tinted, tempered glass side panels and PSU shrouds (ATX)
- Space for a 360 mm radiator at the front
- 280 mm radiator (top of K4) / 120 mm radiator (rear of K5)
- Long graphics cards compatible: fits up to 350 mm (K4) / 310 mm (K5)
- Compatibility with CPU coolers up to 160 mm tall
- 4x 120 mm fans + 2x 120/140 mm fans (K4) / 4x 120 mm fans (K5)
- Drive bays: 2x 3,5 / 2,5″ HDD + 2x 2,5″ SSD / HDD
- I/O Panel with 1x USB 3.0, 1x (K5) / 2x (k4) USB 2.0 and RGB-LED controller
Spacious Midi-Tower & Unique Design
Both the Kolink Inspire K4 and the Kolink Inspire K5 are affordable ATX Midi-Towers suitable for style-conscious gamers with limited budgets. Particularly striking are the fronts of the cases which feature translucent stripes that are illuminated courtesy of a digitally addressable RGB-LED strip, helping to give the cases a look that stands out among the competition. Side grilles help to ensure your components receive an uninterrupted supply of fresh air. On the top of the case, users will find the I/O panel with either one (K5) or two USB 2.0 ports (K4) as well as a USB 3.0 port and the control for the digitally addressable RGB lighting, which can alternatively also be connected to the motherboard via a 3-pin cable should you prefer.
Affordable ATX Case from for Gamers
When it comes to water cooling, Kolink has got you covered – these cases place a high priority on maintaining a spacious and uncluttered interior to help ensure users enjoy as much flexibility as possible when it comes to the installation of high-end cooling gear. As such, a 360 mm radiator can be installed at the front, and the top of the K4 supports a radiator up to 280 mm in size, while the K5 allows for a 120 mm radiator to be mounted in the back. The drive cage beneath the PSU shroud in both cases allows for two 3,5- or 2,5″ drives, while the back of the motherboard trays supports the installation of two further 2,5″ drives. When it comes to cable management, the right side panel of the K5 is equipped with an expanded space for cable management purposes.
