Kolink’s Series PSUs boast an optimized circuit design leading to performance increase. There is also an extremely quiet 120 mm fan with smooth and precise RPM curve that enhances airflow.These PSUs will look amazing in high-end gaming systems due to their modern design and the flexible and flat cables used for connections across the system. Kolink offer these PSUs in two versions: The Modular Power versions, which has partial modular cable management and the Classic Power versions, which comes with fixed cables.
![Kolink Module image](https://img.overclockers.co.uk/media/image/kolink_module.gif)
The Features of the Kolink Power Series:
- 400-, 500-, 600- and 700 Watt power supply with 29-, 37-, 45.5- or 54A single rail
- 80 PLUS Bronze certification
- Quiet 120mm fan with durable sleeve-bearing design
- Modern flat cable, optionally semi-modular cable management
- Up to four 6+2-pin PCIe connectors for graphics cards
- Up to six SATA- and two Molex connectors
![Kolink Power Series Fan image](https://img.overclockers.co.uk/media/image/kolink_power_series_fan.gif)
In order to make the Power series PSUs as efficient as possible, Kolink utilises LLC resonance converters and DC-DC technology with independent voltage regulation, even on the 3V and 5V rails. The result improves efficiency as well as the precision of power delivery, particularly under asymmetric loads. This means that the Kolink Power is, depending on the exact model, capable of delivering 29, 37, 45.5 or 54 Amps on the +12 Volt rail while maintaining stable power delivery to all of your other components. The high efficiency, 87 percent when used on a European-style 230 Volt grid, is confirmed by 80 PLUS Bronze certification. All the requisite and expected safety mechanisms such as short circuit, overload, over- and undercurrent protection are present as a matter of course.
The Kolink Power series is cooled courtesy of a whisper-quiet 120mm fan. It spins at low speeds, and uses exceptionally durable sleeve-bearings. Needless to say, these power supplies deliver everything the modern savvy PC builder could ask for. In addition to the standard >20-4-pin ATX- and 4+4-pin 12V EPS connectors, depending on the model, up to four 6+2-pin PCIe- as well as six SATA- and two Molex connectors are available. This means that multiple graphics cards can be powered simultaneously without the power supply so much as breaking a sweat. For environmental reasons, Kolink has opted not to include a standard kettle cable with the power supply.
