The popularity of Small Form Factor (SFF) PC cases continues to grow, and with that in mind Kolink now offers a refresh to their Rocket Mini-ITX case.
The Rocket v2 shares with its predecessor a notably small footprint – it has dimensions of just 350 x 150 x 270 (mm), but it adds a total capacity of 13.8l. Plus the case is now entirely constructed from 2.5mm thick aluminium and there is a USB 3.2 Type-C port on the front panel.
Small on the outside big on the inside
Other standout features include an updated side panel that has ventilation holes for improved airflow. There is also a high performance 92mm slim PWM HDB fan and 280mm PCIe16x Gen3.1 riser cable included with the case.
Despite its diminutive size, however, there is support for 2.5 Slot VGA Cards up to 330mm and SFX & SFX-L PSUs. Additionally, there is now support for 92mm AiO coolers or 63mm CPU coolers.
All in all the Kolink Rocket v2 strikes the perfect balance between size and performance
