Update 18.07.2018:
The Kolink Observatory is now also available in white!
Powerful and expensive hardware deserves an appropriately well-designed case. To that end Kolink has introduced two stylish cases in which any E-ATX motherboard or long graphics card will fit comfortably. The tempered glass side panels allow you to admire your hard-earned PC hardware from afar as it powers your gaming experiences. But how to take that feel-good factor and raise the stakes yet again? With watercooling, of course – and there’s more than enough space for that too. We recommend the addition of some lighting to complement your components. The Observatory makes a start on this with the addition of four pre-installed RGB-LED fans. Kolink proves once again that style doesn’t need to cost the earth.
Kolink Stronghold: Lots of Space for Lots of Hardware!
- Designer case for motherboards up to E-ATX
- 4 mm tempered glass side panel
- Brushed-aluminium-look front panel
- 2x pre-installed 120 mm fans, total of 6 possible
- Support for two 240 mm radiators
- Supports graphics cards up to 38 cm long & CPU coolers up to 16 cm high
The view through the tempered glass side panel allows you to view the spacious interior of the Stronghold along with the PSU shroud. Beneath that is concealed the drive cage for holding 2,5“- or 3,5” drives. The case reserves plenty of space for large GPUs up to 38 cm in length. Removable dust filters in the roof and floor allow a huge amount of space for watercooling, two pre-installed fans and ingenious cable management are just some of the many highlights of the stylish Kolink Stronghold.
Kolink Observatory: Lots of Space for Lots of Hardware!
- 4 mm tempered glass side panel, glass front
- 4x 120 mm RGB fans including controller and remote
- Support for two radiators in 240 mm format
- I/O Panel with 2x USB 2.0 / 1x USB 3.0 & HD-Audio In/Out
- Graphics cards up to 38 cm long & CPU coolers up to 16 cm high
Kolink’s Observatory expands on the design of the Kolink Stronghold with the addition of a few stylish highlights. Instead of a closed front panel this case opts for a transparent acrylic front. Situated behind the panel are three pre-installed RGB-LED fans and another in the back. They cover the case’s interior in vibrant colours, and to control the illumination simply use the controller and remote bundled with the case. Kolink’s Observatory is a great-looking case that can be improved upon even further with the addition of your own personal lighting!
