Are you looking for a small yet powerful air cooler for your next build? If so, Kolink has you covered with their first CPU cooler; the Umbra EX-180.
![Kolink Umbra EX180](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/desktop-image-2210-kolink-ex-180-1024x342.jpg.webp)
Kolink is best known for their exceptional PC cases and power supplies. Now they are extending their line of accessories with a CPU air cooler. With this remarkable hardware, you’ll have a powerful CPU cooler in a small package. Measuring just 157mm high and 75mm wide, this compact cooler won’t interfere with your RAM modules! Furthermore, the EX-180 will work with a wide range of CPUs, thanks to mounting kits for the latest Intel and AMD processors. But that’s not all, as Kolink has stamped their unique style all over this amazing piece of hardware that is sure to compliment any gaming PC aesthetic.
High-Efficiency Cooling
![Kolink Logo on CPU cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/cpkl_002_05-300x300.jpg)
Kolink knows a thing or two about keeping components cool for optimum performance, as demonstrated by their exceptional line of PC cases. They have utilised this knowledge to create a small form factor CPU cooler that boasts a TDP of 180W.
To achieve this performance, Kolink has utilised four 6mm copper heat pipes that make direct contact with the IHS of the CPU. This innovative design permits the heat produced by the CPU to be channelled away from it extremely quickly.
![CPU cooler direct contact heat pipes](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/cpkl_002_08-300x300.jpg)
This heat is then transferred to the fin stack of the CPU cooler, where it quickly dissipates to the surrounding air. This fin stack is formed of forty-one aluminium sheets that measure 130mm by 0.3mm. Furthermore, this CPU cooler utilises an Electrophoresis process to coat the whole cooler in a stylish black coating. This special coating impedes heat radiation far less than traditional coating would.
Every Cooler Needs a Fan
![Top view Kolink Umbra EX-180 CPU cooler](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/cpkl_002_02-300x300.jpg)
Alongside their experience with cases, Kolink also produce a range of exceptional PWM fans. This CPU cooler is equipped with a 9-blade design to accompany the Umbra EX-180. With this design, this fan can achieve exceptional airflow while being whisper quiet.
The included Kolink fan is able to run at speeds ranging from 800 RPM to 1800 RPM. When running at 100%, it can achieve an astounding airflow of 73.6CFM, while maintaining an impressive static flow of 2.12mmH2O. Although this fan offers incredible performance, it still doesn’t go above 28.6dB(A). That’s as quiet as leaves rustling in a breeze. Kolink has utilised two innovations to achieve this amazing feat of sound dampening. Firstly, the EX-180 has vibration pads where the fan makes contact with the cooler. These pads isolate the fan from the cooler, preventing any vibrations produced from being transferred. Secondly, the hydraulic bearings reduce the internal friction leading to less whine.
The Umbra EX-180 comes with a choice of two types of fans. The Black Edition features an all-black 120mm PWM fan. Meanwhile, the ARGB Edition features a beautiful LED-lit PWM fan with a clear hub and blades. The RGB of this fan can be controlled via your motherboard through a 3-pin 5V connector, for a unified aesthetic with your other RGB components.
Order Yourself a Kolink Umbra EX-180 CPU Cooler Today
Are you considering a small form factor build and need a cooler that can maintain your CPU at peak performance? Then why not order this outstanding cooler today!
![Kolink Umbra EX-180 Black Edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/cpkl_002_01-300x300.jpg)
Kolink Umbra EX-180 Black Edition CPU Cooler
- 180W TDP
- Four 6mm copper heat pipes
- Compatible with Intel and AMD CPUs
- Whisper quiet operation
- 120mm PWM fan included
Kolink Umbra EX-180 ARGB Edition CPU Cooler
- 180W TDP
- 120mm addressable RGB PWM fan
![Kolink Umbra EX-180 ARGB edition](https://www.overclockers.co.uk/blog/wp-content/uploads/2022/10/cpkl_001_01-300x300.jpg)
