The only thing better than a highly efficient cooling system is one that looks stunning, too. Enter the Kolink Umbra Void ARGB Performance AIO Range.
![Kolink Umbra Void ARGB AIO Range: Expert Cooling](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/blog-kolink-umbra-void-aios-1024x1024.png)
These CPU coolers take advantage of high-performance water cooling and iconic infinity mirror lighting to elevate your thermal solution. This range of AIOs has been engineered to draw heat away from your CPU and keep it operating at optimum temperatures, whilst retaining a competitive price point. Oh Kolink, you do spoil us so!
The Kolink Umbra Void ARGB Performance Range
There are three models in the Kolink Umbra Void ARGB Performance CPU Cooler range: a 120mm, 240mm, and 360mm. Each comes with Kolink Umbra Void SP 120mm ARGB PWM fans, to enhance the performance and style! As you would expect, the 120mm has a single fan, the 240mm has two, and the 360mm has three.
120mm
![Kolink Umbra Void ARGB Performance AIO 120](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-120.jpg)
Mount: On the rear panel of your PC case
240mm
![Kolink Umbra Void ARGB Performance AIO 240](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-no-fans.jpg)
Mount: On the top or front panel of your PC case
360mm
![Kolink Umbra Void ARGB Performance AIO 360](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-360.jpg)
Premium Materials
To ensure optimum performance, the Kolink Umbra Void AIOs have been manufactured from premium materials and components that cohesively work together. All in the name of keeping your processor at the optimum temperature.
The radiator is constructed solely from aluminium and features a high-density fins stack design. Pairing a great thermally conductive material with an enhanced surface area means this radiator will draw heat from the coolant with incredible efficiency. What’s more, the copper base and 13.4W/mk thermal paste only optimise this performance further.
To enhance durability, the pump shaft and bearing are manufactured from ceramic and can reach speeds up to 2600RPM. This keeps the coolant flowing through the system smoothly. The liquid is piped through the system via dense rubber tubing with a braided sleeving. These tubes are flexible, enabling smooth bends and easy installation. To further enhance this, the CPU cap can rotate a full 360-degrees.
![Kolink Umbra Void ARGB Performance AIO pump](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-pump-300x300.jpg)
![Kolink Umbra Void ARGB Performance AIO radiator](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-radiator-300x300.jpg)
Kolink Umbra Void SP Fans
Of course, one of the star features of these AIOs is the inclusion of Kolink Umbra Void SP 120mm ARGB PWM fans. Veritable cooling powerhouses in their own right, these fans effectively exhaust heat from the AIO system thanks to their maximum airflow of 65.2CFM and static pressure of 3.9mmH2O. What’s more, they feature a Zero RPM mode, so you can enjoy silent performance when working under lighter loads.
![Kolink Umbra Void ARGB Performance AIO fan screw holes](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-fan-screws-300x300.jpg)
![Kolink Umbra Void ARGB Performance AIO 240](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-240-300x300.jpg)
ARGB Lighting
In addition to efficient cooling, the Kolink Umbra Void ARGB Performance AIO CPU Coolers boast phenomenal aesthetics. Both the CPU cap and fans have vibrant ARGB lighting that can be configured into a dazzling array of colours. LEDs are integrated into the fan frame, making the blades simply glow as they spin. The CPU cap and fan hub both feature the iconic infinity mirror effect, for elite-tier style.
Lighting cables connect to your motherboard and, as such, your light show can be configured from compatible software.
![Kolink Umbra Void ARGB Performance AIO 120](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-120-300x300.jpg)
![Kolink Umbra Void ARGB Performance AIO pump cap](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-pump-cap-300x300.jpg)
Compatibility
Whether you are Team Red or Team Blue, the Kolink Umbra Void Performance AIO is for you! These CPU coolers are designed to work with both AMD and Intel sockets! Check out their full compatibility list below:
AMD
- AM5
- AM4
- AM3+
- AM3
- AM2+
- AM2
- FM2+
- FM2
- FM1
Intel LGA
- 1700
- 1200
- 115x
- 2066
- 2011-V3
- 2011
- 1366
Keep Cool and Carry On
If your gaming PC is missing some cooling and colour, then you’re in luck! The Kolink Umbra Void Performance ARGB CPU Coolers are available to pre-order from Overclockers UK now! Drop a comment below if you’ll be making the upgrade.
- All in one, water-cooling CPU coolers
- Pre-installed Kolink Umbra Void SP 120mm PWM fans
- Iconic infinity mirror effect lighting
- Premium build materials
- Available in three sizes
![Kolink Umbra Void ARGB Performance AIO 360](https://www.overclockers.co.uk/blog/wp-content/uploads/2023/08/kolink-umbra-void-aio-360-300x300.jpg)
