You may be looking to level up with the new year. A shiny new PC case could be just the upgrade your gaming PC needs. Enter, the Kolink Unity Solar and Cascade.
These mid-tower PCs are feature-rich, engineered to expertly balance aesthetics and cooling. You can show off your PC with pride and remain confident it’s all to temperature. What we like to call a win-win. On top of this, they have been optimised to support high-end hardware across a wide range of the available market. A win-win-win!
What’s Available?
There are three cases available. The Kolink Unity Solar ARGB PC Case comes in black or white, whilst the Kolink Unity Cascade ARGB PC Case just comes in the classic black finish.
Unity Solar
Unity Cascade
Solar vs Cascade
The Kolink Unity Solar and Cascade have both been designed to optimise cooling, but in different ways. From pre-installed PWM fans to mesh panelling, both of these cases have fantastic out of the box cooling.
Unity Solar
For its front panel, the Kolink Unity Solar utilises an ultra-fine performance mesh. This facilitates incredible airflow and serves as excellent dust filtration. Paired with further cooling support, this PC case is ready for all your powerful gaming hardware.
Unity Cascade
The Kolink Unity Cascade is all about enhancing cooling potential. The front panel has a high airflow design, maximising the natural flow throughout the chassis. Plus, with extensive radiator and fan support, you can craft a truly efficient thermal solution to keep your components at peak temperature.
Shared Features
For all their differences, the Kolink Unity Solar and Cascade share a number of features. These all add up to creating a sleek interior that supports an exciting range of hardware. To start with, the backplate can accommodate up to E-ATX motherboards and there are seven expansion slots for PCIe devices. With an additional bracket (sold separately), these expansion slots can support vertical mounting. Pair that with 400mm clearance for GPUs and you can make the NVIDIA RTX 40 Series the centrepiece of your gaming PC.
The chassis features a dedicated PSU shroud, designed to minimise the clutter and therefore optimise the aesthetics. This space can hold ATX power supplies up to 220mm, affording great flexibility and choice with the current market.
For storage, both these PC cases include four drive brackets, providing two each for 2.5” SSDs and 3.5” HDDs. The hard drive brackets are toolless for ease of installation, while the SSD brackets can be mounted in your choice of three locations. Thanks to this, you can engineer a fast and high-capacity storage solution for all your files, media, and, of course, your gaming library.
Finally, the I/O panel is easily accessed on the front. It includes two USB 3.0 ports, a combined headphone and microphone jack, plus buttons for power, ARGB mode, and ARGB colour. Swift and efficient lighting control at your fingertips!
Cooling Support
The ARGB buttons control the lighting on the four pre-installed ARGB/PWM 120mm fans. These are mounted to boost the airflow readily supplied by the mesh panelling. Three are placed on the front, whilst the last fan is on the rear panel.
Of course, there is more support for further fans and radiators. You can craft a fully air-cooled PC or keep temperatures down with water-cooling loops. Plus, with 162mm clearance for a CPU cooler, you have plenty of options to work with. Here is the full breakdown of fan and radiator support:
Unity Solar | Unity Cascade | |
Front Panel | 3 x 120mm / 2 x 140mm fans up to 360mm / 280mm radiator Pre-installed: 3 x 120mm fans | 3 x 120mm / 2 x 140mm fans up to 360mm / 280mm radiator Pre-installed: 3 x 120mm fans |
Top Panel | 3 x 120mm / 2 x 140mm fans up to 360mm | 3 x 120mm / 2 x 140mm fans up to 360mm |
Rear Panel | 1 x 120mm fan 1 x 120mm radiator Pre-installed: 1 x 120mm fan | 1 x 120mm fan 1 x 120mm radiator Pre-installed: 1 x 120mm fan |
ARGB/PWM controller | Included | Included |
Solar or Cascade?
Which of these cases caught your eye? Both the Kolink Unity Solar and Cascade are available to pre-order from Overclockers UK. Drop a comment below with your favourite!
